-   -   Simple way to twin plug? (http://forums.pelicanparts.com/porsche-911-technical-forum/158513-simple-way-twin-plug.html)
rswannabe 04-14-2004 07:15 PM
Ok, now that I have people's attention...
I was thinking about twin plugging motors and an idea occured to me. I'm sure there is something wrong with it, or people would have been doing it for a long time. The idea is this:
Use a regular 6 plug distributor and split each lead (using a "Y" spark plug wire) to run to two plugs at each cylander. I assume you would have to beef up the coil (use two coils?) to supply enough electricity to fire two plugs properly, and beef up the rotor head and cap as well. So why won't this work?
Some possible reasons why it doesn't work:
No way to evenly split the current between the two siamesed plug wires, so one plug ends up getting the majority of the electricty and the other is realatively useless?
Do twin plug systems fire the two plugs at each cylander at slightly different times?
jazzbass 04-14-2004 07:29 PM
Re: Simple way to twin plug?
I pretty sure that's exactly why it won't work - electricity will take the path of least resistance and only fire one plug. Not sure about *when* each coil fires in a dual system, though.
project911 04-14-2004 07:43 PM
Then why not use the induction of the first wire as the control lead (like on a relay) to a coilpack (or whatever) that will provide the power to the second spark plug wire.
1980 911 sc 04-14-2004 08:04 PM
i have an SC. As I under stand it the distributor does two things:
Send a signal to the CDI
act as the switch for each spark plug
When ever the CDI isnt firing it is charging for the next fire...so if you had two CDI boxes you could have twin plg right? wrong! you still need the switch for each spark plug part...
Lukesportsman 04-14-2004 09:21 PM
I think that there is probably the technology today to accomplish this. BUT, I'm not sure it would be any easier or cheaper to produce than the options already on the table. Electromotives solution with direct fire and the removal of the dizzy is just too straight foward for many to search beyond it. This solution gets rid of spark scatter, multi dizzies, coil saturation problems and to some it even looks cool. On the high end many of the EFI controllers are now able to do coil on plug now, so we may see more changes.
aigel 04-14-2004 11:45 PM
The best way to twin plug your engine is to buy a 3.6. :D
project935 04-15-2004 04:46 AM
Time to introduce you to the "search" function on this board ...
Just about every conceivable way to twin plug has been talked about here - just do a search.
cstreit 04-15-2004 07:45 AM
What p935 said.
We beat this one to death last year.
Short answer: Fuhgeddabowdit.
rswannabe 04-15-2004 07:48 AM
Thanks all. I do always try to search before I ask a question. I was pretty sure this wasn't possible, I just wanted to confirm.
