Simple way to twin plug?
Ok, now that I have people's attention...
I was thinking about twin plugging motors and an idea occured to me. I'm sure there is something wrong with it, or people would have been doing it for a long time. The idea is this: Use a regular 6 plug distributor and split each lead (using a "Y" spark plug wire) to run to two plugs at each cylander. I assume you would have to beef up the coil (use two coils?) to supply enough electricity to fire two plugs properly, and beef up the rotor head and cap as well. So why won't this work? Some possible reasons why it doesn't work: No way to evenly split the current between the two siamesed plug wires, so one plug ends up getting the majority of the electricty and the other is realatively useless? Do twin plug systems fire the two plugs at each cylander at slightly different times? Thanks |
Re: Simple way to twin plug?
Chris M 1985 911 Carrera w/ 3.6 |
Then why not use the induction of the first wire as the control lead (like on a relay) to a coilpack (or whatever) that will provide the power to the second spark plug wire.
'70 911T Signal Orange |
i have an SC. As I under stand it the distributor does two things:
Send a signal to the CDI act as the switch for each spark plug When ever the CDI isnt firing it is charging for the next fire...so if you had two CDI boxes you could have twin plg right? wrong! you still need the switch for each spark plug part... |
I think that there is probably the technology today to accomplish this. BUT, I'm not sure it would be any easier or cheaper to produce than the options already on the table. Electromotives solution with direct fire and the removal of the dizzy is just too straight foward for many to search beyond it. This solution gets rid of spark scatter, multi dizzies, coil saturation problems and to some it even looks cool. On the high end many of the EFI controllers are now able to do coil on plug now, so we may see more changes.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Now in 993 land ...
The best way to twin plug your engine is to buy a 3.6.
Time to introduce you to the "search" function on this board ...
Just about every conceivable way to twin plug has been talked about here - just do a search.
Project935 Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06 Gruppe B #101 What's next? |
Super Moderator
What p935 said.
We beat this one to death last year. Short answer: Fuhgeddabowdit.
Thanks all. I do always try to search before I ask a question. I was pretty sure this wasn't possible, I just wanted to confirm.
