sprbxr's Avatar
Send a message via Yahoo to sprbxr
G50/50 Trans removal problem
I posted this on the 964 forum but I thought you guys might know the answer too.
Anyone know the trick for removing the throwout lever pivot? It doesn't want to slide out. Do I need some $pecial Por$che tool for removing it.
Justin
Old 04-16-2004, 06:23 PM
Chris Lovell's Avatar
We just removed the cover to the end of the pivot (driver's side) by backing out the screw. Then I threaded a metric bolt into the threaded hole in the end of the pivot axle. I then gently tapped it out with a small hammer. Mine was easy. Others have had to use a slide hammer.
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 04-16-2004, 06:32 PM
89turbocabmike's Avatar
sprbxr, there is a threaded hole in the cross-shaft that is 6mm-1.0, same as the small bolt that holds that little plate that holds the rubber plug covering the cross-shaft. I used one that was a couple inches long so that I could get a good grip to pull out the cross shaft.
Old 04-16-2004, 06:33 PM
sprbxr's Avatar
I have pulled the ***** out of it and it won't budge. There is no load on it so it should come out. I will try again tomorrow.
Justin
Old 04-16-2004, 06:40 PM
don911's Avatar
I had to use a slide hammer on mine. Do the 964's have the same issue with the cross shaft bearings? If so, make sure there are no bearings stuck on the shaft before you put too much force on it. You can break the ear off the tranny housing if you're not careful. I only know this because that's what happened to me.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 04-16-2004, 07:26 PM
sprbxr, mine was pretty stuck as well. With the long bolt threaded onto the shaft there was enough room to take a screwdriver/chisel to the underside of the bolt head and give it good tap as I didn't have a slide hammer type set-up to break it loose. Didn't have to tap that hard. Let us know how it goes.
Old 04-16-2004, 08:39 PM
