-   -   Front Sway Bar Drop Link Bushings - Help (http://forums.pelicanparts.com/porsche-911-technical-forum/159017-front-sway-bar-drop-link-bushings-help.html)
SteveBorelli 04-18-2004 01:02 PM
Dear all,
it's the first time I'm writing to this forum so, please sorry if I make some mistakes.
First of all I have to thanks Pelican Parts because of their professionality and competence.
This is my problem.
Few days ago I bought from this site the following item :
Front Sway Bar Drop Link Bushings (stock bar), set of 4, 911/911 Turbo (1965-73), 914 All
Now, when I've got the package, disassembled the old bushings and installed the new one, I discovered that the original metal piece inside the bushing had an 8mm internal diameter hole while the new one has a 10mm hole.
Now, the problem is of course that all the original hardware (screws and car brakets) is 8mm diameter setted;
- if I leave the new one I have a not properly good situation given the fact the screw is 8mm and the hole 10mm;
- if I try to reuse just the old 8mm internal diameter iron pieces with the new bushings is not safe because the external diameter of the iron piece is a little bit less than the new one (i.e. it is not kept tight from the bushing);
- I have thought to re-drill the holes in the car brakets (10mm) and to use a right sized screw (10mm) but, before to do this thing and permanently modifing the car, I wanted to have your confirmation or some expert opinion...
But... I have the right pieces or I miss something ?
My car is a 1973 911 E Targa
Please give me a hand.
Thx.
Bye.
P.S. Sorry for the inappropriate language but I'm Italian... ;-)
