Virginia Rocks!
VaSteve's Avatar
Originally posted by Par911
Toss it, your car will feel more nimble.
Don't listen to Pari, he takes everything out of his car.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 04-20-2004, 05:16 AM
Broke
Westy's Avatar
For those of us that are slightly older, and NEED that A/C unit that's attached to the motor,,,how much is the Rotary upgrade with the bigger condenser? And who sells them? And, is the Rotary without the newer condenser good enough? And , , ,well, I think you get the idea.
B.
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 04-20-2004, 06:54 AM
swbsam's Avatar
it's kind of funny that you should post this at this time as I am having the complete system redone, last august when I bought my 87 TL one of the things that I knew that wasn't working was the air, well... a lot of you might say, well the air in these cars was never any good anyway and from what I can remember from the few times I tried to use the air in my 84 it wasn't worth the loss in power or gas mileage it cost to use it , well not to far from me is a place called Scott's Independent and besides being a great place to get your car worked on ( and the official R GRUPPE BBQ site at Dunkel's this last year ) a division of their business is called Performance Aire, for some years now I have heard a lot of people talk about them and the things they can do that will vastly improve the air in Porsche's, so now I'm about to find out if spending three grand to change out just about every component in the system will really make this thing blow ice cubes, here's a link to their site and some pic's of the work their doing :http://www.scottsind.com/scotts.htm then click on work in progress.
they will have the car for about a week, I'm leaving for Daytona Thursday and when I get back Tuesday I'll have a couple of days to play with the car then it's off to Monterey on Thursday for the fifth annual R GRUPPE North meets South meeting, I'm not sure if it will really be warm enough to properly test the new air at this time of the year as last year it was in the 60's and rainy up in Monterey, but if the sun's out I'm sure it will at least get up into the eighties, so I'll find myself hoping for warmer weather.
sam
Self anointed Head of the SSSP
( Super secret seat police )
our motto is : if you've got a bug up your ass, we put it there
67S polo red - gone but not forgotten
87 factory M491 turbo look lagoon green metallic
Old 04-20-2004, 07:05 AM
San Antonio, jeez, you really need A/C there. Stealthn, Canada? You're kidding right?? It gets up to what, 80 in August there??
Mine works and even though it takes a bit to get the car cool it is really nice to have here in Houston, With more money you can get them to work pretty well (mine's stock). I can easily see removing the thing if you are in Cali and or other places with moderate weather or if you only drive the thing in nice weather. Mine is a daily driver. Driving to work in the morning in the summer or home in the afternoon is not much fun without A/C.
Old 04-20-2004, 07:06 AM
Broke
Westy's Avatar
WOW!! I'm not sure I want to be 3K Kool. Hmmmmm, it IS a Targa!
93 968 Cab
Old 04-20-2004, 07:08 AM
swbsam's Avatar
one of the things I've learned over the years " you get what you pay for "
sam
Old 04-20-2004, 07:20 AM
Send a message via ICQ to old_skul
Mine's in a box. Compressor, condensor, reciever/drier, lines...it weighs about 75 pounds.
Open a window.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 04-20-2004, 08:12 AM
Broke
Westy's Avatar
I weigh 240. What's another 70?
93 968 Cab
Old 04-20-2004, 08:33 AM
Send a message via AIM to Tommy B
with no AC you'll be sweatin those pounds away in no time!
My car had the AC removed by the PO. If i could find a cheap setup i'd put it back in in a sec. My car is frickin hot, and im in NY where it hasn't even broke 90 yet.
Old 04-20-2004, 08:37 AM
Pulled mine out of my "77 3 months after I had it. Still in a box in the garage. I'll give it to the next owner.
I'd leave the hoses, evap. and blower (usually in the smugler's box) as it will still give you some cabin air circulation.
Not worth the time or effort to remove all the ancillary stuff. You can tuck or tie-wrapp the hoses back against the firewall out of the way and tape off the any electrical connections.
End result: cleaner engine bay-easy access to other stuff (valves) and the hood shocks will really work now.
I agree- early 911's (mid 70's)were never designed for AC. Every installation I've ever seen looked like a "hack" job.
If it doesn't leak, you're out of oil.
If you took a picture of a Porsche and put it in your shirt pocket it would leak oil on your shirt.
Screw Flanders....
I'm goin' to Moe's.
Old 04-20-2004, 08:53 AM
Fix it
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 04-20-2004, 08:58 AM
Send a message via AIM to fintstone
Cheapest that I have found to add AC setup is ICE in San Diego....Their setup is reported to provide cool air at outlet in the low 40's. They will fix your existing system and convert it to a Seiko rotary reasonably and replace your hoses with barrier type. They seem to be a good value for areas that do not get extremely hot. If I had an existing system, I would try this first (under $1K). If you need an entire system, with underdash unit, it is under $2k installed, http://www.iceac.com/ice.html
but the underdash unit does not look quite as much like the factory version as the one from Scotts Independent does: If you are somewhere that gets really hot...and want outlet temp to get down to the 30's, you are talking about either Scotts Independent (Performance Aire) as posted earlier: http://www.scottsind.com/ who uses a Seiko rotary compressor and a static underbody condensor ($3k+ depending on what you have to start with)
or Griffiths who use a Sanden swash plate compressor and additional condensors in the left rear wheel well: http://www.griffiths.com/ (around $3k+ depending on what you have to start with)
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-20-2004, 09:23 AM
Broke
Westy's Avatar
Now THAT is good info. A/C is in the car, It just needs upgrading.
Thanx
93 968 Cab
Old 04-20-2004, 09:40 AM
limble's Avatar
Gut it, it's dead weight. Save it for the next owner.
Any tips for storing the compressor?
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 04-20-2004, 09:41 AM
vash's Avatar
i use mine as a door stop for my back garage door. i "condomed" all the drip points with cut off fingers from my nitrile gloves. it looks "ready for love" just sitting there
poof! gone
Old 04-20-2004, 12:55 PM
geof33's Avatar
Thanx
Ok, let's see... It's gonna cost you around three grand (that's what I was quoted) to do the "upgrade" you still get mediocer sp?? A/C at best, that will be useless in any condition over 80degs.
Let's say you do it all yourself. Parts, around 1000.00, maybe a bit more depending on what compressor you buy... If you don't have a front condensor, you'll need it cause the underhood one won't cut it. Then you get to remove all the stuff... Getting the hoses OUT requires either some really patient fishing or cutting and yanking... which is still kind of a pain. THEN you have to reroute all of the lines... OMG I don't even want to think about that one... SO... your in all this time, money, brews, headaches for an "OK" A/C... That is worth MAYBE 1000 more when you sell it... (I doubt that)
Or, you loose 100 LBS off the car, sweat a bit more and go faster and your car runs better, cause it never has to lag because of an AC... Never sell the car cause it's your baby and "it's allll goood"...
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 04-20-2004, 01:07 PM
Broke
Westy's Avatar
OK, but how do keep the beer cold????
93 968 Cab
Old 04-20-2004, 01:09 PM
joecrum's Avatar
Drink it before it gets warm...
joe
>82 3.0 SC
>01 Audi S4 Avant
Old 04-20-2004, 01:16 PM
Nah..If you have an existing system in decent shape, you can get an upgraded compressor, hoses and new dryer for a little more than $1k installed at ICE..or so they say. That would most likely be enough for gentle climates. And, of course, the rotary compressor consumes much less HP to operate. Call them and see.
Old 04-20-2004, 01:20 PM
Moke81's Avatar
Just for curiosity sake how much does the Seiko-Seike rotary vane compressor and new evaporator dryer that is listed under 911 Tech Articles on this web site go for?
Old 04-20-2004, 01:54 PM
