Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Kink in oil line at tank
Hey Guys, I know I read about this somewhere, but can't find the thread.
The rubber line that goes from the oil pump line, around the back of the motor and up to the tank, with the bent metal end, has a kink in the rubber when I installed it. Either the angle of the metal portion is too great, or the rubber is too long.
Whats the solution?
TIA
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 04-23-2004, 05:32 PM
vash's Avatar
john, if you loosen up the fittings at either end, can you "rotate" the hose to release the kink? this is what i had to do, and as a bonus the hose just sat against the car better, making that M6 stud easier to work with.
cliff
poof! gone
Old 04-23-2004, 05:35 PM
Stahlwerks.com
jhelgesen's Avatar
Yeah, I tried that, it just flattend the kink a little instead of it being at an angle. If I could take an inch or so out of the rubber part, it would be fine.
John Helgesen
Old 04-23-2004, 05:38 PM
vash's Avatar
well, i remember the past post. that was the beotch of the matter. the hose was too long. i think the verdict of the past post was to return the hose. that bites!
poof! gone
Old 04-23-2004, 06:30 PM
Or,
Remove the hose, cut the crimp off carefully, remove the end, cut the hose 2 inches off, put the hose back on the end, use 2 hose clamps.
It works, may be not as beautiful, but it works.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-23-2004, 10:00 PM
Stahlwerks.com
jhelgesen's Avatar
I couldn't get our host on the phone yesterday afternoon (it was late, about 4pm their time) maybe I'll try again today, not sure if they have sat hours, see if they have a shorter hose by now. I know I bought the first one from them.
John Helgesen
Old 04-24-2004, 02:00 AM
