Stiffness Hollow vs Solid T Bars
I've been doing some research on hollow T bars on this bulletin board and in the PCA archives and I've not been able to find anything on the relative stiffnes of a hollow vs solid tbar of the same diameter. There have been several references to the weight advantage of the hollow bars and some vague mention that a hollow bar will be less stiff than a solid bar, but nothing specific.
I know that the stiffnes of a solid bar is porportional to the 4th power of the diameter. My engineering intuition also tells me that the stiffnes of a hollow bar should be proportional in some way to the difference between the inner and outter diameters. I would guess that the stiffness is proportional to the 4th power of the outter diam minus the 4th power if the inner diam.
This may seem arcane to some of you however, I have a set of hollow 28 mm bars that I am planning to install in my RSR Clone project car and I am worried that they may be too stiff for my street driving.
Does anyone have the answer??
Old 04-28-2004, 02:05 AM
IROC's Avatar
For the same outer diameter, the hollow bar will be slightly less stiff than the solid bar. Use the equation J=pi/32(D^4-d^4) to calculate the polar area moment of intertia for a hollow bar (vs J=pi*D^4/32 for a solid bar) and then the theta = Tl/JG equation to determine relative "spring rates".
The short answer is that - depending on your definition of stiff - I don't think 28mm bars (hollow or not) will be "too stiff" for street driving.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-28-2004, 03:24 AM
Original Owner
tsuter's Avatar
The hollow bars cheat by .5mm or so, so that their "effective" spring weight is the same as the equivalent solid bar.
The difference is weight. That's why you buy hollows.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 04-28-2004, 04:31 AM
dickster's Avatar
tom
i am using 31 hollow and they are fine on the street.
Rich
'86 coupe
"there you are"
Old 04-28-2004, 05:03 AM
Somewhere in the Midwest
MotoSook's Avatar
I've got 32 mm hollow tubes in the rear with Sport shocks...not to stiff for me liking...the key is to match the shock to the spring rate.
Old 04-28-2004, 05:58 AM
Yep, some vendor has a chart that says what the similar solid bars are. I think tsuter is right, the hollow bars are about .5mm larger to get the same stiffness.
Old 04-28-2004, 06:17 AM
Chuck Moreland's Avatar
Vendors of hollow bars publish the size as "equivalent" diameter.
A 28mm hollow has the same spring rate as a 28mm solid, but if you get the calipers out you'll find it is not 28mm.
They do this so you don't have to do the math.
Chuck Moreland - elephantracing.com - vonnen.com
Old 04-28-2004, 12:02 PM
