1fastredsc's Avatar
Send a message via AIM to 1fastredsc
The final stretch.... anyone with a 3.0!
Here are three pictures that are baffling me, i don't know where the vacuum hoses go (i have an 83 with two vac lines going to the distributor). I also still haven't figured out where that support thing goes to.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 04-26-2004, 12:45 PM
1fastredsc's Avatar
bump
2007 Mazda 3 hatch
Old 04-26-2004, 02:12 PM
oneblueyedog's Avatar
http://www.pelicanparts.com/911/911_Parts/1978-83/1-7-3.JPG
This should solve it.
Old 04-26-2004, 02:21 PM
Hald's Avatar
On my '77 3.0, the upper of the two vacuum ports in your first photo is attached to a port on the lower section of the warmup regulator.
The lower port is attached to thermal valve, shown below.
[img]
Mark
'77 Carrera 3.0
http://members.rennlist.com/hald
Old 04-26-2004, 02:35 PM
ZAMIRZ's Avatar
Looks like you're using hose techniques vacuum lines. I did the same after I had some wierd high-idle problems and it solved that, they're very durable and fairly cheap too.
Amir
'83 911SC
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Fastred,
The top TB port pictured goes the the WUR.
The bottom TB port pictured goes to the back side of the dizzy vac. advance.
There are two TB ports facing the firewall. The one facing stright back goes to the decel valve, the other that is slightly facing the fuel distrib. goes to the top side of the dizzy advance.
See pic:
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 04-26-2004, 02:37 PM
1fastredsc's Avatar
Thanks guys!!!! One blue eyed dog, where did you find that cis diagram?
2007 Mazda 3 hatch
Old 04-26-2004, 03:21 PM
konish's Avatar
red,
The bracket holds the two hoses up, slightly behind the airbox. i removed mine when I changed my shocks. Essentially, the two hoses will run perpendicualr to the centerline of the car (athwartships). There is a blind nut just on the backside of the the airbox bracket and the whole thing is held on by (if memory serves) a small 8mm bolt. I do remeber it being tiny...and I dropped it about 6 times before I got it to thread. Feel around behind the airbox and you'll probably understand better. I shoot a quick pic for ya, but I don't think a chinese contortionist could get back there with digital cam...
R/
Dustin
Old 04-26-2004, 05:08 PM
In the Pelican parts site. In the "Parts Diagram" section on the left side of the Porsche page.
78SC coupe, Silver Metallic
Old 04-26-2004, 06:16 PM
1fastredsc's Avatar
It feels like since i started school i've been getting dumber, thanks.
Thank's for the help with the bracket, i'll see if i can find that airbox mount for it.
2007 Mazda 3 hatch
Old 04-26-2004, 09:53 PM
Information Overloader
Mark,
I'm looking at your pic. I have that electrical connector but it doesn't attach to anything. It's flopping in the breeze. I also don't have that thermo switch. Can anyone tell me what the story is for my '83 3.0 SC? I can't tell from emeory waht I have in that area, though.
Old 04-27-2004, 05:14 AM
Hald's Avatar
Jimcry,
This CIS stuff is fairly new to me. I need to study the wiring diagram & figure out what that thing (thermal valve) does & how. It sits between the TB & WUR. The wires to the connector disappear into the harness atop the engine. The can't go far! ;^)
Mark
'77 Carrera 3.0
Old 04-27-2004, 05:46 AM
Mark,
From faulty memory and other shoddy research, think the wires go to the thermotime switch on the left chain housing. Do a search with 'thermotime' and a pic will come up. A guy had the same question as I but the answer left me even mor confused (as if that were possible).
Old 04-27-2004, 05:50 AM
Mark,
It's the "What does this connect to?" thread.
Old 04-27-2004, 05:57 AM
1fastredsc's Avatar
From looking (in great detail) at the wiring diagram for the 83 sc, i believe the connections for to the left thermo time switch go to the cold start valve and the signal wire for the starter (which is where the cold start valve get's it's power). That thing in the picture has me lost, i don't even think i had one on the car.
2007 Mazda 3 hatch
Old 04-27-2004, 04:52 PM
pjv911's Avatar
Send a message via AIM to pjv911
The 1983 cars didnt have one. Thats why you cant find it.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 04-27-2004, 05:38 PM
