-   -   3.6 Cyl Head Temp Sensor Location... (http://forums.pelicanparts.com/porsche-911-technical-forum/160351-3-6-cyl-head-temp-sensor-location.html)
Mike Feinstein 04-27-2004 11:44 AM
I know it's at/near cyl #3, but does anyone have a picture, or good description of its location? Is it accessible from the engine bay, or underneath the engine? Anything special to know about changing it out? I believe I need a 14mm wrench with the end cut out for the wire...will probably use a flare-nut wrench.
I suspect it is at the heart of my cold starting problem.
Any help would be great.
Thanks,
MuffinMan 04-27-2004 12:15 PM
My head temp sensor was broken upon arrival of my engine, so I replaced it during that time.
I don't know how similar it is on 993 engines, but here's the Pelican article for replacement on a 3.2.
Carrera head temp sensor replacement
code7rpd 04-27-2004 01:12 PM
It is on the rear of the motor and has a black rubber plug over it. The wirecoming from it should be white and encased in a plastic sleeve. I believe you need a 14mm 12 pt socket that has to be cut down to fit - it is a PITA.
scca_ita 04-27-2004 02:57 PM
Divers side/front of the engine - two wires
1 from the flywheel sensor and the other to the side of it is the temp sensor. There are no other wires
Embs 04-27-2004 03:16 PM
http://forums.pelicanparts.com/uploa...1083104192.jpg
Embs 04-27-2004 03:22 PM
http://forums.pelicanparts.com/uploa...1083104574.jpg
Bill Verburg 04-27-2004 03:37 PM
Todd, It looks like you learned a lot about that engine:)
Embs 04-27-2004 03:44 PM
Not bragging, but I could drop it and install it by myself in under an hour. These cars are the easiest (mechanically) thing to work on ever.
First I loved VW Beetles, then 914's and 911's. To this day nothing comes close. Germans...
I have been busy, but watch your mail.
Mike Feinstein 04-27-2004 03:51 PM
Exactly what I needed.
Thanks!
