3.6 Cyl Head Temp Sensor Location...
I know it's at/near cyl #3, but does anyone have a picture, or good description of its location? Is it accessible from the engine bay, or underneath the engine? Anything special to know about changing it out? I believe I need a 14mm wrench with the end cut out for the wire...will probably use a flare-nut wrench.
I suspect it is at the heart of my cold starting problem.
Any help would be great.
Thanks,
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 04-27-2004, 11:44 AM
MuffinMan's Avatar
My head temp sensor was broken upon arrival of my engine, so I replaced it during that time.
I don't know how similar it is on 993 engines, but here's the Pelican article for replacement on a 3.2.
Carrera head temp sensor replacement
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 04-27-2004, 12:15 PM
It is on the rear of the motor and has a black rubber plug over it. The wirecoming from it should be white and encased in a plastic sleeve. I believe you need a 14mm 12 pt socket that has to be cut down to fit - it is a PITA.
Old 04-27-2004, 01:12 PM
scca_ita's Avatar
Divers side/front of the engine - two wires
1 from the flywheel sensor and the other to the side of it is the temp sensor. There are no other wires
Old 04-27-2004, 02:57 PM
Embs's Avatar
Old 04-27-2004, 03:16 PM
Embs's Avatar
Old 04-27-2004, 03:22 PM
Bill Verburg's Avatar
Todd, It looks like you learned a lot about that engine
Bill Verburg
Old 04-27-2004, 03:37 PM
Embs's Avatar
Not bragging, but I could drop it and install it by myself in under an hour. These cars are the easiest (mechanically) thing to work on ever.
First I loved VW Beetles, then 914's and 911's. To this day nothing comes close. Germans...
I have been busy, but watch your mail.
Old 04-27-2004, 03:44 PM
Exactly what I needed.
Thanks!
Mike
Old 04-27-2004, 03:51 PM
