Jcon's Avatar
Need pics of drivers side fender oil cooler
I'm moving along nicely with the 3.6 conversion. I tackled the exhaust issue and despite the great advice on this board I conquered the issue with a large check for a unit from kenny Mcneil at AWE.
Now for the oil cooling. I already have a fender mounted cooler on the passengers side so I'd like to add another on the drivers side. Does anyone have pics or a description of how you went about this set up. I'm broke so no more check book mechanic.
Jeff C
Jeff C
76 912E 2.6L
Old 05-02-2004, 02:26 PM
Jcon's Avatar
Quick Bump for the west coast crowd
Jeff C
76 912E 2.6L
Old 05-02-2004, 05:28 PM
rfix'n's Avatar
The biggest issue you will run into is clearance, the battery box takes up some space on this side. Make sure you buy a cooler narrow enough to compensate for this.
I also mounted mine upside down on the drivers side to make running the lines easier.
Sorry, no pics but the rest of the install is similar to the passenger side.
Rob Fix
'78 3.6L SC Targa
Eiche Gruen Metallisch
Old 05-03-2004, 06:59 AM
http://vintagebus.com/howto/cooler/index.html
I still have this cooler and one of my Kustom brackets (the other one is still welded to the car)
Old 05-03-2004, 07:10 AM
Administrator
Jack Olsen's Avatar
Ryan has a nice write-up of this in a thread. Thom has it documented on his site, too.
My driver's side cooler is upside-down.
Old 05-03-2004, 09:34 AM
Jcon's Avatar
Excellent write-ups..Thanks
What did you guys end up doing with the fuel expansion tanks?
Jeff C
Jeff C
76 912E 2.6L
Old 05-03-2004, 11:10 AM
Early_S_Man's Avatar
Porsche Crest
FYI, in case anyone out there is interested who has expressed doubts about the temperature ratings of 12 Volt computer fans of the 6.5" variety that I have recommended ...
On this past Saturday I began a long-term reliability test of four Nidec Beta V TA600DC thermostatically-controlled [internal control, two speeds, 235 cfm rating at 'high' speed] fans to replace one of the radiator fans on my wife's '94 Nissan that had not been funtional for at least a year or so ... this will be a bit more rigorous test than front fender oil coolers on a 911, since the radiator runs more or less around 195°F anytime ambient temps are above 35°F or so ...
http://www.nidec.com/ta600dc38/ta600dc38.htm
The temps underhood are at least 20°C higher than the rated specs, so I think this will shorten the fan bearing life a bit ... but at least I got the whole set for $20 on eBay, instead of the distributor price of $72 per fan!
I will let you know when any problems occur in 'testing!'
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-03-2004, 12:22 PM
rfix'n's Avatar
Good stuff Warren, thanks! I think I'll be adding a $20 fan to my drivers side cooler. I don't recall the guage wire used for the passenger side fan, it would be nice to run the drivers side off of the same relay.
Regarding the fuel expansion tank I eliminated it. Looped the hose around and zip tied it at the highest point in the fender well, no problem for over a year now.
I also got rid of the windshield washer tank, planned on putting it under the hood but have not gotten around to it. In the winter I drive around with a squirt bottle of fluid / water in the cabin.
Rob Fix
'78 3.6L SC Targa
Old 05-03-2004, 12:33 PM
Jcon's Avatar
rfix'n -
Sounds good I can still afford zip ties!
Anyone see any reason the expansion tank can't be eliminated?
I will probably relocate the washer bottle under the hood ( A different bottle)
Jeff C
76 912E 2.6L
Old 05-03-2004, 01:01 PM
