Senior Member
The older (67 and previous) Jags all had a button for the starter. Worked great but then it probably was not made by Lucas...
![]() JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Here is an installed pic in case you have not seen it.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
I hope you guys know how much current the switches can carry.
or do you plan on using a relay ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Insert Tag Line HERE.....
The new Vipers have them also, and no doubt cheaper than Honda.
Marc |
Hey rattle - have not seen you around for a while, how about posting some pics of the progress on the race car! or did I miss it?
Would the Dodge dealer be able to get the button for me?
I just got it back from the body shop yesterday. The body has been done for 4 months. In other words it took him 3-4 months to finish the hood scoop thingy he made. If it werent for the price of the whole job, I would be very p.o.'d
Marc |
911 driver
Elombard,
Here's a picture of the start button in my BMW racecar project. To start the engine the ignition key must be in the ON position. This provides current to the momentary toggle switch. You press the switch to the right, then push the START button with your thumb. Wired this way the steering lock will be off, and since you must use two buttons at the same time you will not engage the starter by accident while the engine is running. Still easy one hand operation. You MUST use a relay. The start button is from a pinball machine! I found it on eBay. (Got another one that says "To Be Continued". Not sure what to do with that one yet... ) It even comes with a small bulb to light itself. Good luck!
Ove '77 911S targa |
Cool thanks. I was planning on a relay. Isnt there one built in to the start circuit already? If I just pull the wires off the back of the relay - wont it have a relay already?
Gon fix it with me hammer
honduh parts in a 911 ?!?!
blasphemy
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
911 driver
Not sure about the original circut, but you must have a relay or the button will melt from the high current flow.
This would look good in an early 911 Do a search for "start button" on eBay
Anyone who wants to do this upgrade most read this link: http://web.ics.purdue.edu/~cnicol/Z8%20Start%20Button/
X/A |
Great link - thanks
My ignition wouldnt start the car, so I ran a wire from the starter to the dash and another from the dash to the fuse box, I touch them together to start. Last week I bought a momentary switch with a red flip-up cover to put in, but I haven't gotten around to it yet. It's like the nitrous switch from Eleanor in Gone in 60 Seconds. The C/D and stuff are still wired through the key, so it has to be in the ignition for the car to start. Nobody's theivin' me...
'74 with webers... Ferdinand Porsche's concerto in flat-six major... |
This thing is up for auction on the New Zealand 'TradeMe' site.
A bit like a poor mans e-bay . Buy now price is about $100 USD It is probably a bit rice as it requires a 25.4[1 inch] hole !
I saw the Pivot buttons on E-bay here tooo. But I did not know they came in Red. Looks about the same but its more money than the actual Honda Part??
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
I have a heavy diesel truck and it starts by turning the key to on and then pushing a start button that is rubber covered.
It has 3 - 12 volt batteries and a BIG starter motor so it's nessessary to deal with the current. It's cannon ball proof
On a great circle route
A remote switch in the engine compartment for maintenance is a neat idea, just be sure it is not parked in reverse...
Russ |
on e-bay for $60.00 buy it now whit relay and you can choose red or blue
X/A |
