Elombard's Avatar
Start button instead of Key?
Any body done this? I think its cool on the Honda S2000. Seems like you could make up piece to replace the key with a start button so it would look factory?
Too rice??
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-29-2004, 08:24 AM
addictionMS's Avatar
in my race car...but then I have no key at all, and it does not look factory...never mind
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 04-29-2004, 08:32 AM
I'd think you'd want to retain some sort of keyed unlocking feature, so as to discourage people from simply pushing the button and driving off with your car. The S2000 actually has a key to unlock the ignition, then the pushbutton. So maybe in addition to the key, but not a replacement. You'd also have to add some sort of driver/solenoid combo so that the button would actually engage the starter, which would require weight.
The more I type, the less of a practical idea it seems to me. I agree though, it would be cool. Especially if it were under the dash or something. Maybe a keycode, like in "the transporter?"
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 04-29-2004, 08:42 AM
SweetE's Avatar
I have 2 Porsches with the "key-Starter button" combination.
My 56 356 Speedster and 67 911S racecar.
When the ignition switch in the 67 failed to start the car, I wired in a starter button and it works great
The key turns on the power and the button engages the starter
Old 04-29-2004, 09:37 AM
Early_S_Man's Avatar
Porsche Crest
The keyed ignition switch can continue to supply all regular circuits, and the button would relieve the switch of starter solenoid current load ... thereby extending the life of the ignition switch by some percentage ...
I did this on a VW Type III ... starter button is on the left side of the steering column, under the dash, and hot all of the time, but it won't start unless the ignition key has been turned on!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-29-2004, 09:41 AM
Glasgow 911SC's Avatar
You can buy starter button kits like this one but I've no idea why they're so expensive.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 04-29-2004, 11:35 AM
Friend of Warren
Or you can set it up like my Bugeye Sprite which like many early British cars had a separate keyed ignition switch and a starter pull. That's right, in typical British quirkiness instead of a button you push, there is a knob on the dash you pull to engage the starter. I never lock the ignition because only a British car nut would know how to start the damn thing!
Kurt V
Old 04-29-2004, 01:26 PM
Hmm, so you're saying it might make sense to utilize the existing equipment, rather than tear out what's there and put in new stuff to do the same thing.....intriguing.....
I'm an idiot. I guess the only thing you'd need to do is disconnect the final circuit in the keyed ignition and run that to the button.
89 Carrera 3.4
Old 04-29-2004, 02:00 PM
Elombard's Avatar
Hmm, that is a cool kit. I think I saw in a mag somewhere that a guy had bought an S2000 button assembly (big red and says "start") and put it on his car. I did not realize the key locked the steering - doh. I was going to work out another security option. That would be cool to just put the button next to the key. I am going to look into the Honda button. It would be nice to do away with the key but maybe not too secure.
Old 04-29-2004, 03:01 PM
Might be a good idea since ignition switches are pretty expensive replacement items.
Regarding the smarty-party push button switch. Does anyone actually need a visual cue the engine has started? I guess if you need this type of assistance, then it might be worth the extra bucks.
Since there's minimal space for one of those classic start buttons, one could install a SPST momentary ON-OFF toggle switch with the appropriate current capacity or a small capacity switch and a relay. Connect in parallel with the existing switch and you then have a choice how you crank.
Sherwood
Old 04-29-2004, 03:45 PM
A Quiet Boom's Avatar
On my old drag car I had a standard race type push button on the dash as well as one under the hood. I used the one under the hood to bump the engine over for valve adjustments or to start the car from the engine bay for other reasons like tuning, jump starting etc. I also had an ignition kill mounted right next to it. These items came in very handy but I admit the in cab button was unnecessary in my case. Warrens suggestion to reduce wear on the key switch in a P-car makes a lot of sense though. You could also hide it under the dash as an anti theft device.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 04-29-2004, 05:23 PM
Navin Johnson
TimT's Avatar
You can do it with a $2 momentary switch from Radio Shack
easy
'69 911 GT-5
'75 914 GT-3
and others
Old 04-29-2004, 05:35 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I've heard it being integrated into the "normal components". I've heard of one story where a guy rewired a chevy pickup so that he had to pull out the ashtray to energize the ignition and push in the cig. lighter to activate the starter. Very cool and kinda scary at the same time!
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-29-2004, 05:44 PM
Elombard's Avatar
For me its all about the looks and feel, sorta 60s Le-Mans. There is no reason for it- I just like it. I had a push button start in my old datsun race car. I always got a thrill pushing the button. Cant wait to get my car back and see if ther is room on the dash next to the key to do it!
Old 04-29-2004, 07:40 PM
I have the Honda switch uninstalled. Temporarily, take a look.....
Oh, and it works only with the key. I can also start the car the regular way (for Valet).
Another benefit is that I end up 'conserving' my factory ignition switch. Those suckers are expensive.
Old 04-29-2004, 08:56 PM
I just read about a 40amp Longacre pushbutton starter sw
w/weatherproof rubber cover for $8.99
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-30-2004, 12:22 AM
Porsche's Avatar
What a great idea. I'm installing a push button for my C2 wing - I may do this at the same time.
Erwin
'97 Boxster (sold), '67 911S (sold), '77 911 (sold)
Definitive Australian/ New Zealand Porsche Resources
Old 04-30-2004, 12:28 AM
Originally posted by Porsche
What a great idea.
a direct hot from the big starter feed to an engine com sw to the solenoid isn't a bad idea.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-30-2004, 12:32 AM
I want to try and mount the button in a shifter knob. Mercedes does it best.
Think Intergalactically Act Interplanetarily
Old 04-30-2004, 03:50 PM
Elombard's Avatar
Here it is:
Here is a link to the kit. I saw another site where they are $35for the Honda part w/ wiring harness. Included the part number.
http://www.mx5parts.co.uk/product_info.php/products_id/136
Is it just me or would it look just right in a pre 89 911 cockpit!!
Oh here is a link to a place that sells it for $35
http://www.handa-accessories.com/
And here is a link to a detailed install instructions from a honda board similar to this. Turns out it almost drops in the Cigarette
lighter hole!!
http://www.miata.net/garage/pushstart/
Old 04-30-2004, 03:55 PM
