Nathan M's Avatar
Question 3.2 idle CO adjustment?
I understand there's a small screw to adjust the CO at idle only. Where exactly is this and what CO% value should it be set at? It's currently 3.9% and smells very rich at idle. (I do have access to a gas analyser)
3.2 Coupe
Old 04-26-2004, 04:23 PM
Nathan M's Avatar
anyone?
3.2 Coupe
Old 04-27-2004, 05:41 AM
Install425's Avatar
The adjustment screw is on the drivers side back corner of your mass air flow.
Rob,
88 911 Turbo
Old 04-27-2004, 06:07 AM
Friend of Warren
The search button is your friend:
DME and Idle Fuel mixture adjustment
Kurt V
3.9% ? Where are you taking your measurement from, before or after the cat?
Joe
Old 04-27-2004, 10:12 AM
Nathan M's Avatar
Thanks guys.
3.9% from the exhaust tailpipe. My car has no cat anyway.
Nathan
3.2 Coupe
Old 04-28-2004, 04:43 AM
CO should be 1% or less.
Cheers,
Joe
Old 04-28-2004, 03:22 PM
Make Bruins Great Again
Por_sha911's Avatar
If you don't have a cat, your car will smell like its running rich because the cat takes some of that smell out of the exhaust. If you live in a non-emissions state then don't worry about running a little rich IF the car runs (and idles) well and you're not fowling plugs. Better to run a little rich than to run lean.
Joe
Old 04-28-2004, 05:41 PM
Assuming you're running an 02 sensor, set it to spec or be prepared for flat spots and poor low end performance.
Or you could leave it rich and suffer the consequenses of premature valve guide wear and increased oil consumption...etc.
Might as well forget about smog issues too.
Joe
Old 04-29-2004, 01:10 PM
