no spark
ok, I know this has been brought up before, took motor and tran. out to replace clutch, put evrything back the right way?????
and now I have no spark? did notice that the ground wire from tran. to body was broke, didnt think that would stop spark? anyone got any ideas. thanks mark |
Put that big fat ground wire back.
What model Porsche are we talking here?????
Tell us mooooore...............
sorry 1970 911 targa 2.2. also seems like when I touch points or anything around the points it zaps, like the whole dist. is charged. this is when checking to see if I open and close points do I get a spark,
anyways I dont get a spark accross points?? will put big ground wire back on today will update all thanks again mark |
Check the installation of your condensor. Make sure it's attached correctly.
condensor should be on left hand side of engine ?
mark |
The condensor should be either inside or attached to the distributor ... but, only if you have a conventional -- battery- coil ignition!!!
<b>Your car SHOULD HAVE a Bosch CDI system, and that system does not have a condensor accross the points!!!</b> |
| All times are GMT -8. The time now is 09:04 AM. |
