no spark
ok, I know this has been brought up before, took motor and tran. out to replace clutch, put evrything back the right way?????
and now I have no spark? did notice that the ground wire from tran. to body was broke, didnt think that would stop spark? anyone got any ideas. thanks mark |
Put that big fat ground wire back.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
What model Porsche are we talking here?????
The Fox Carrera |
Tell us mooooore...............
Mike 83 SC |
sorry 1970 911 targa 2.2. also seems like when I touch points or anything around the points it zaps, like the whole dist. is charged. this is when checking to see if I open and close points do I get a spark,
anyways I dont get a spark accross points?? will put big ground wire back on today will update all thanks again mark |
Check the installation of your condensor. Make sure it's attached correctly.
The Fox Carrera |
condensor should be on left hand side of engine ?
mark |
The condensor should be either inside or attached to the distributor ... but, only if you have a conventional -- battery- coil ignition!!!
Your car SHOULD HAVE a Bosch CDI system, and that system does not have a condensor accross the points!!!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 05-02-2004 at 07:40 AM.. |
