on-ramp's Avatar
Originally posted by bell
looking at the relay attatched to that harness it looks to be a starter kill.......if you cut it the car will not start....it'll need to be reconnected (the stock wiring, this is a "loop").......best to trace each wire and disconnect individually so to be sure the stock wiring is intact where the connections were made.
this is what you mean?
Old 05-02-2004, 02:21 PM
one of gods prototypes
bell's Avatar
yes but without tracing the wire it's hard to say why it's there.......
Brought to you by Carl's Jr.
Old 05-02-2004, 02:24 PM
You should trace each wire to its destination and unhook them, then seal. You do not want a bunch of wires hanging around to start trouble.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 05-02-2004, 03:01 PM
MBAtarga's Avatar
Somewhere in that harness is +12V DC from your batttery. If you cut that wire and it shorts somewhere to your chassis, you can have sparks or even a fire. As suggested, you should trace down where each wire is routed and remove it at the source.
Mark
'83 SC Targa - since 5/5/2001
Old 05-02-2004, 04:15 PM
ruf-porsche's Avatar
Want to sell the radio and all the wire harness after you are done removing it from your car?
Old 05-02-2004, 06:04 PM
on-ramp's Avatar
sure, how much could i get?
Old 05-02-2004, 06:30 PM
84porsche's Avatar
Send a message via Yahoo to 84porsche
The aluminum box is just the mounting frame - I pulled the release clips on the old unit then reversed the metal locks for the frame and took that piece out separately - then replaced it - I have more pix of my install if you need them -
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 05-02-2004, 09:04 PM
84porsche's Avatar
Looks like you got a project going - but it looks possible - after I put my stereo in at got it working I have more hope for future projects - the last time I worked on the car - I was playing with the transmission and when I was out driving I knocked the shift rod out of the shift coupler and ended up driving home in 2nd - luckily I was only down the street -
2003 VW Jetta GLI
Old 05-02-2004, 09:09 PM
I check ebay and a refurbished unit that was never installed with the box went for $27.00.
How about $25.00 plus shipping?
Link to ebay auction
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3288&item=3092334203&rd=1&ssPageName=WDVW
Old 05-03-2004, 03:17 AM
