Gas Overflow, Why?
For years now, I can only fill my 1972 911T gas tank half full. If I put more than half a tank in, gas will liberally run out in the engine compartment, out of a thin metal tube on the left engine compartment wall, near the fuel pump. If I have just short of a half tank, and I get on it hard, gas will again get washed back and it comes out of the tube. Can I cork the tube? Lengthen the tube? Thank you in advance.
I don't have a solution for you, just wondering how you dare driving around with that for so long. A little spark and your car is history.
Perhaps it's your fuel return line. |
that line in the engine compartment is the stock fuel line, figure out how the fuel is getting to you motor, I am guessing that someone has modified it, I would for starters put some fuel line on this metal tube and jam a bolt or something in the open end, pout a hose clamp on it and seal it off.
If you are not mechanically inclined, get it into a shop to sort this out. Jim |
Frank,
Post a picture of exactly where the leak is coming from. The two most likely sources are fuel line and the evaporative emissions system. Best, Grady |
I suspect someone has removed the vapor recovery system form your 1972. You need to find the original parts aor at least rig up something. See:
http://forums.pelicanparts.com/porsche-911-technical-forum/128087-help-i-smell-gas.html?highlight=Vapor Jim |
Its fixed with bolt in the fuel line to plug to line.
Thanks |
'87 fuel on the ground during SMOG test
The mechanic took the gap cap off to do a pressure test while the engine was running. I found a puddle of gasoline on the ground, under the left front gas tank area. Does removing the gas cap while the engine is running , cause fuel to flow to the ground from the overflow tube?
Thanks, Caliber |
Caliber, you need to make your own topic for your problem, so as not to confuse between people/cars/problems.
edit: Oh, I see you just made your own. Good SmileWavy |
| All times are GMT -8. The time now is 06:39 AM. |
