Red face Gas Overflow, Why?
For years now, I can only fill my 1972 911T gas tank half full. If I put more than half a tank in, gas will liberally run out in the engine compartment, out of a thin metal tube on the left engine compartment wall, near the fuel pump. If I have just short of a half tank, and I get on it hard, gas will again get washed back and it comes out of the tube. Can I cork the tube? Lengthen the tube? Thank you in advance.
Frank in Naples, FL
1972 911T
1983 944
Old 05-04-2004, 09:28 AM
palle7688's Avatar
I don't have a solution for you, just wondering how you dare driving around with that for so long. A little spark and your car is history.
Perhaps it's your fuel return line.
You might not be happier owning a Porsche, but it certainly feels so driving one
Old 05-04-2004, 09:35 AM
addictionMS's Avatar
that line in the engine compartment is the stock fuel line, figure out how the fuel is getting to you motor, I am guessing that someone has modified it, I would for starters put some fuel line on this metal tube and jam a bolt or something in the open end, pout a hose clamp on it and seal it off.
If you are not mechanically inclined, get it into a shop to sort this out.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 05-04-2004, 09:43 AM
Grady Clay's Avatar
Frank,
Post a picture of exactly where the leak is coming from.
The two most likely sources are fuel line and the evaporative emissions system.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 05-04-2004, 10:30 AM
I suspect someone has removed the vapor recovery system form your 1972. You need to find the original parts aor at least rig up something. See:
Help I smell gas!
Jim
Old 05-04-2004, 11:00 AM
Its fixed with bolt in the fuel line to plug to line.
Frank in Naples, FL
1972 911T
1983 944
Old 01-18-2006, 04:03 PM
'87 fuel on the ground during SMOG test
The mechanic took the gap cap off to do a pressure test while the engine was running. I found a puddle of gasoline on the ground, under the left front gas tank area. Does removing the gas cap while the engine is running , cause fuel to flow to the ground from the overflow tube?
Thanks,
Caliber
Old 02-18-2009, 02:02 PM
Band.
Caliber, you need to make your own topic for your problem, so as not to confuse between people/cars/problems.
edit: Oh, I see you just made your own. Good
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 02-18-2009, 02:10 PM
