slater's Avatar
Jetting / fuel pressure for Zeniths?
Couldn't find my answer in the search, so I will have to ask-
Putting zeniths on my 75 2.7s (stock CIS) engine- How should I have the carbs set up for best performance (jets and so on) and what fuel pressure will I need? I have a CIS pump right now, so I assume I will need a pressure regulator. Any help is appreciated. -Kris
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 05-07-2004, 12:16 PM
al lkosmal's Avatar
slater,
Go to the PMO website. They have all the jetting info. If you strike out send me an emaill, I have the info at home. Also I would suggest a lower pressure fuel pump regulated down to 3.5psi or so. I think Pelican has these (Facet??)
Al
RGruppe #669
http://www.x-faktory.com/
Old 05-07-2004, 12:58 PM
slater's Avatar
thanks!
Old 05-07-2004, 02:26 PM
al lkosmal's Avatar
Venturi = 32mm
Main jets = 135
Idle jets=55-60
Air correction jets=180
Emulsion Tube=F26
RGruppe #669
Old 05-07-2004, 10:03 PM
