Adjustable Sway Bar Arms for Early Factory Bars??
I am planning on using the stock factory front and rear sway bars as the starting point on my RSR clone project. Does anyone where I can get adjustable arms that will work with the stock front sway bar and drop links?
The rest of the suspension consists of JRZ single adjustable raised spindle struts with 23 mm hollow T Bars and an a Carrera aluminum cross member for the front. The rear has 30 mm hollow T bars with alloy trailing arms and Bilstein sport shocks. I am using the Elephant Racing polybroze bushings and monoballs front and rear. |
