Porsche Crest 87 cab squeak/noise
Hello
My 87 cab squeak when go over speed bump and the noise came from the rear passenger side, I have tightedn all nut and bolts on the fram, but the noise does not go away, the car has 44K miles and the top stillin excellent condition
any other area I suppose to check.
TC_SJ
Old 05-08-2004, 08:33 PM
Eric Coffey's Avatar
Just guessing, but I'd bet it's probably a rear shock, sway bar, T-bar, or trailing-arm bushing(s). You should probably expect more flex and noise from a cab though too.
Old 05-08-2004, 09:16 PM
DJB DJB is offline
DJB's Avatar
Its not the end of the zip on the rear window rattling is it?
Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module
997 C4 Cabriolet - Basalt Black
86 Turbo Body 911 Cab - Many Mods
Gone and Missed:
97 993TT: PSS9, CarGraphic Exhaust
Old 05-08-2004, 11:24 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Do you hear it with both the top up and down? I would bet it's the suspension as well - check the shock top and bottom.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 05-09-2004, 05:02 AM
the top made squeaky noise either up or down position.
I have my kid seat in the rear seat and she sure the noise was from there.
TC_SJ
Old 05-09-2004, 07:14 PM
Check for cracked or broken sway bar mounting tabs. Very common on these cars.
Ray
'88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia
Old 05-10-2004, 05:36 AM
Ray
Could you please point to the exact location, I have the Bentley manual, but does not cover the cab portion.
Tan
911 1987 Triple Black Cab Turbo Look >> weekend car
SPF MK III Shelby Cobra 427 550HP >> thrill for speed
BMW 88 635CSi daily drive
BMW 87 325i use for rainning day (donation)
Benz 06 E350 use for pick-up kid on car pool day
Old 05-10-2004, 09:18 AM
Sure Tan. Look under the car just forward of the rear tires. You will see where the sway bar attaches to the chassis just rearward and inboard of the rear jacking point. The sway bar runs laterally across the rear of the car and connects the bananna arms together via a drop link. The mounting points seem to fail on these cars due to the fact that the cars got heavier over the years (more stress) without a proportional increase in the strength of the mounts. Seems like it's the pass. side that to fails more often. You may an assistant help you rock the car or simply jack the car up to see a crack( it may appear normal at rest). Sorry if I oversimplified the description- we have everything from pros to novices on this board. I'm not a pro- I have simply learned from my experiences. Best of luck. Ray
Ray
Old 05-10-2004, 06:37 PM
