How to check for valve guide wear.
I am getting ready for a valve adjust on my C2. While I have the valve cover out, I'd like to check my valve guide for wear.
I understand that I can use a screwdriver to wiggle the valve? Where/how would I do that? Use a screw driver to try and wiggle where the arrow is on the picture below right? And I must do this when the valve is closed right? ![]() thanks, anthony |
Anyone?
I've never done this but my understanding is that the valve must be open to do the check. If the valve is closed the stem wont rock back and forth because the head of the valve is keeping it from moving. If you want to try it I would have the valve open about .1 inches and push on the valve stem to see if it will move sideways. Don't know how much they should move. I usually just assume they are ok until oil consumption gets too high or I see carbon building up on the valve stems and springs.
-Andy
72 Carrera RS replica, Spec 911 racer |
JW has posted that the wiggle measurment isn't the best..
but the book says a wear limit of .15 for intake .20 for ex for '65-'89
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Who is John Galt?
Smoke after decceleration is a good indicator. Next time you get off the highway, coast to the end of the exit ramp under high engine rpm to generate a strong vacuum in the intake manifold. If your guides are worn, you'll suck oil into the intake down past the valve guides and there will be lots of smoke.
'79 911sc Targa '02 slk230 kompressor '84 Tamiya Falcon A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years. |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Frankly, I'd have a hell of a time guessing how much a screwdriver is moving a valve stem back and forth. I think you have to know what you are doing to really use this. Although I suppose if its really moving you probably have worn valve guides. If you are using a lot of oil and blow smoke on decel just assume you need valve guides.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
If you can detect movement the guides are worn. Valve guide seals are another consideration for oil burning.
From reading the old posts, I'm a bit confused. Are the movements up and down or sideway?
---- anthony |
Side-to-side!
77 911 |
Who is John Galt?
