1990 C2 Targa
I am considering buying a 1990 C2 Targa. The care has 70,000 miles on it with a pretty complete book of service records. It is very clean and seems to have been well cared for. Have not been able to drive the car yet as it is in storage. That will happen later this week. Since these cars had a history of Cylinder head leaks I am a little apprenhensive. There are no service records of any dealer doing warranty work for this potential problem. I have read both the Porsche 911 buyers Guide (by Leffingwell) and Porsche 911 performance handbook (by Anderson). They both say only a small % of these models had the problem. However it could run up a bill of around $5K. Does anyone now if Porsche North America would be able to tell me if the work had been done by one of their dealers if I give them the VIN? How concerned should I be about this if the car checks out strong on the test drive?
MBruns for President
$5K - They haven't priced a complete rebuild lately using new P & C's. To properly fix a cylinder head issue - you need to replace both (and machine the case) - I think it was BA who said it's not a question IF the 1990-1991 3.6 will need this fix completed - but when.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Automotive Monomaniac
Get a PPI (Pre-Purchase Inspection) by a Porsche mechanic.
I'd be concerned about a car in storage. Small issues can creep up on cars that are not driven (moisture in fuel tank, brake lines, etc...).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
You can, and we do, re-machine the existing heads and cylinders (if they are within wear tolerance spec) to repair this problem. Plenty of other shops do the same thing.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
It depends on what was worn. If the wear on the cylinders was sufficient to be out-of -spec, then you need new ones. The heads are relatively easy to machine, there is a Porsche special tool to hold them for machining. The only machining on the cylinders is to accept a seal ring at the top.
A lot of the early cars have already been modified, one way or another, to repair the potential leak. If it was a customer pay job then there will be no info at Porsche and there's no way of seeing it either. Personally, if the rest of the car is perfect and you are going to keep it for a long time, just accept that maybe you might need to do the engine one day. It's a used car, things go wrong.
Are you saying if a Porsche Dealer did the work then you could find a record of it or do I understand you to say that no matter who did it, if you don't have a service record receipt you won't know? On page 48 of the 911 Performance Handbook by Anderson he says that " The cars built in 1990 (L) are susceptiple to the cylinder head to cylinder leaking problem. He goes on to say the early cars were those built up to 62 M 06836, M64.01 for the manual transmission cars. Where do these numbers appear? I am guessing they are the numbers stamped on the case? Final thought, if I have the motor leak tested and it checks out good should it be safe to say the car either had the leak problem and it was fixed properly or given that it has 70000 miles on it the motor won't have this kind of problem until much later in it's life? Thanks for your input.
Here's my 1990 C2 Targa at 72,000 miles. the PPI at 62,000 said it had a oil leak around the power steering pump and missed the cylinder head leak!
Thanks Jeremy. Did you get rid of your C2? Would like to talk to via phone about that car if you don't mind. I am Florida as well. Your Cab looks great, especially with your little girl inside! Gotta get'em started young.
It was hit by a yellow cab - rear ended - totalled the car - I got out with a sore neck - that's all.
![]() I'll PM my phone number and email address. I still miss my C2 - It was more expensive to maintain - but a hoot to drive.
