1st Gear Problem With 84 911
LATELY I HAVE BEEN HAVING TROUBLE GETTING MY TRANS INTO FIRST GEAR WHILE AT A STAND STILL. NOW I CAN'T ENGAE FIRST GEAR AT ALL. I ADJUSTED THE LINKAGE FROM THE TIPS GIVEN BY PELICAN AND I CAN ENGAGE EVERY GEAR (2-3-4-5 & REV), BUT I CAN'T GET IT INTO 1ST. I WOULD REALLY APPRECIATE SOME HELP.
THANKS,
BILL
Old 05-09-2004, 12:04 PM
Has the transmission ever been overhauled? When it would go into first did it do so without grinding if the car was moving? If you have addressed the shift coupler issue and it still won't go into first, the synchro hub (dogteeth) for first gear may have failed with allows the first gear synchro ring to expand to the point where the the operating sleeve (slider) will not go over it and permit engagement of first gear. If this has happened there are likely fragments of broken first dogteeth loose in the tranmission. It would be prudent to look at the drain plug magnet (make sure you can loosen the fill plug first before removing the drain plug) for evidence of broken dog teeth (look for little triangular shaped bits) and also remove the the shift fork cover on the bottom (to check for debris) once you have drained the transmission oil. If fragments are loose one should cease driving the car for if these fragments go through the mesh of a gear set they can ruin the gears and increase the cost of the tranmission overhaul. Jim
Old 05-09-2004, 12:52 PM
Sorry to hear this, Your tranny is due for a total rebuild. Expect $1200 for the box, and then installation charge.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-09-2004, 12:54 PM
Semper drive!
rcecale's Avatar
If a rebuild is due, he COULD do it himself...
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 05-09-2004, 02:33 PM
the whole tamale is in that recent thread by rcecale. 4 pages worth and counting.
206 637 4071
Old 05-09-2004, 06:43 PM
THANKS TO ALL WHO REPLIED. I HAVE MY MECHANIC COMING OUT TO MY HOME TOMORROW NIGHT AND HE IS GOING TO LOOK AT AS MUCH AS HE CAN USING A FLOOR JACK. I'LL KEEP YOU POSTED ON WHAT HE FINDS.
BILL
Old 05-09-2004, 07:38 PM
Semper drive!
rcecale's Avatar
By the way, Bill, welcome to the board!
As I have, I'm sure you'll find this place to be a wealth of information regarding your Porsche. Just come on in and strap yourself down, cuz it can come at you even faster than you ask for it!
Randy
One Marine's View
Old 05-10-2004, 04:11 AM
