-   -   no spark!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/162246-no-spark.html)
MARK SHUART 05-09-2004 02:16 PM
no spark!!!
ok fix clutch problem, now have no spark, have 70 targa2.2 have 12v going into dist. no volts at blue and yellow wire at coil.what next??.............help thanks mark
Jim Sims 05-09-2004 03:05 PM
Did you remove the distributor, coil or wires or otherwise disturb anything? Have you checked points dwell and timing? Jim
jess p 05-09-2004 04:15 PM
no spark
Did you by chance disconnect the ground strap from the tranny to the chassis?
MARK SHUART 05-10-2004 03:13 AM
I did remove coil when trouble shooting(wires) and I did have running rough before I did clutch, just bought a month ago but did have spark.
What I did do is when motor was out cleaned engine area with carb. cleaner and sprayed out with hose, did not run for a week after that so it should of been dried? also there is a ground wire with the blue and yellow wire where should it be connected to and one on each hinge on engine cover where do they connect?
That is installed jess . thanks everyone
