-   -   Tach works under hard acceleration, but reads high otherwise -- what gives? (http://forums.pelicanparts.com/porsche-911-technical-forum/162752-tach-works-under-hard-acceleration-but-reads-high-otherwise-what-gives.html)
Rich911E 05-12-2004 04:49 PM
I have a weird problem with my tachometer. It bounces around and reads very high (like twice the real RPM) under part throttle. If I mash the gas, it reads just fine. I have an Mallory Hy-fyre MSD style ignition box with a point type distributor. I tried wiring in the MSD tach adapter but that didn't work either.
Any ideas?
Alternator, voltage regulator???
Thanks in advance.
Rich
Rich911E 05-13-2004 08:59 AM
bump -- anybody?
B D 05-13-2004 09:08 AM
The "Mallory Hy-fyre MSD style ignition box" is a multiple spark unit correct? Does it have a wire or plug in for a tach?
doozer 05-13-2004 09:09 AM
could it be only reading incorrect when the ignition is not advanced / retarded?
Does the Hy-fyre produce 20deg of spark at low rpm and reduce to single spark at high rpm?
could be you connected to the coil output as a tach trigger rather than the dedicated tach output on the ignition box ( if it has one )
Hope this helps...
Todd
jluetjen 05-13-2004 11:00 AM
I'd double-check with the folks at MSD. It sounds like you have something wired wrong because your tach is reading the multiple sparks rather then the RPM. I had some questions when I was installing my MSD and they were very helpful and knowledgeable.
- John
Rich911E 05-13-2004 12:31 PM
Thanks for the suggestions.
The Mallory box is a multiple spark unit and has a line for the tach and that is where it hooked up. I am not sure about the advance characteristics. I didn't get a lot of help from Mallory with my last request by e-mail. Maybe I'll talk to MSD -- I am sure they know the unit as well.
Thanks -
