Tach works under hard acceleration, but reads high otherwise -- what gives?
I have a weird problem with my tachometer. It bounces around and reads very high (like twice the real RPM) under part throttle. If I mash the gas, it reads just fine. I have an Mallory Hy-fyre MSD style ignition box with a point type distributor. I tried wiring in the MSD tach adapter but that didn't work either.
Any ideas?
Alternator, voltage regulator???
Thanks in advance.
Rich
2004 GT-3
1969 911E
1988 944 Turbo
1990 BMW 325i
2001 BMW Z3
Old 05-12-2004, 04:49 PM
bump -- anybody?
2004 GT-3
1969 911E
1988 944 Turbo
1990 BMW 325i
2001 BMW Z3
Old 05-13-2004, 08:59 AM
B D B D is offline
B D's Avatar
The "Mallory Hy-fyre MSD style ignition box" is a multiple spark unit correct? Does it have a wire or plug in for a tach?
68 911L
Old 05-13-2004, 09:08 AM
doozer's Avatar
could it be only reading incorrect when the ignition is not advanced / retarded?
Does the Hy-fyre produce 20deg of spark at low rpm and reduce to single spark at high rpm?
could be you connected to the coil output as a tach trigger rather than the dedicated tach output on the ignition box ( if it has one )
Hope this helps...
Todd
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 05-13-2004, 09:09 AM
jluetjen's Avatar
I'd double-check with the folks at MSD. It sounds like you have something wired wrong because your tach is reading the multiple sparks rather then the RPM. I had some questions when I was installing my MSD and they were very helpful and knowledgeable.
- John
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-13-2004, 11:00 AM
Thanks for the suggestions.
The Mallory box is a multiple spark unit and has a line for the tach and that is where it hooked up. I am not sure about the advance characteristics. I didn't get a lot of help from Mallory with my last request by e-mail. Maybe I'll talk to MSD -- I am sure they know the unit as well.
Thanks -
2004 GT-3
1969 911E
1988 944 Turbo
1990 BMW 325i
2001 BMW Z3
Old 05-13-2004, 12:31 PM
