Doug Steinel's Avatar
bulk spark plug wire
I have a new set of spark plug connectors but am having trouble finding the bulk wire to make my own set of plug wires? Anybody know where I can get it?
77 911, 3.0L
Old 05-15-2004, 03:14 PM
Go to Google and type, "Spark plug wire bulk". One of the first ones that popped up was Taylor. They offer resistance wire as well as metal core versions.
Sherwood
Old 05-15-2004, 04:06 PM
djmcmath's Avatar
Boy, I wish I had been that lucky two weeks ago. Hours on Google got me nothing conclusive... I ended up at Napa and bought a 100' roll of 7mm metal core.
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 05-15-2004, 09:15 PM
CarQuest.
'80 SC
Old 05-15-2004, 09:44 PM
Sherwood,
Taylor's website only talks about 8 mm wires.... but mine are 7 mm. I am afraid they won't fit my connectors... am I right?
77 911, 3.0L
Old 05-16-2004, 04:21 AM
djmcmath's Avatar
I'm pretty sure that's right, but it's hearsay for me to say that because I've never actually tried to stuff 8mm wires into 7mm end connectors, but have only read painful reports from other people who have. If Taylor doesn't have 7mm's, drop by your friendly local Napa Auto Parts store. Not nearly so convenient as ordering online and having shipped straight to your door, but an operable solution nonetheless.
Dan
Old 05-16-2004, 08:11 AM
I haven't tried squeezing 8mm wires into 7mm connectors either, but doesn't Magnacore do this with stock Beru connectors? Or do they somehow bore out the connector; or are Magnacore wires also 7mm? Don't know, but I'm sure others do.
I don't see the harm in reducing the OD by 1 mm so it slips easier into the connector. You may have to do the same with the ends where they slip into the distributor cap. As far as the wire separators, people slit the opening so the fatter wire can slip through or purchase 8mm wire separators from the many hot rod sources.
Sherwood
Old 05-16-2004, 01:36 PM
Senior Member
Superman's Avatar
Motorcycle shops have some.
Mocha 1978 911SC. "Coco"
Old 05-16-2004, 02:27 PM
