fancytown
Brake caliper rebuild tip...
I'm not sure if I'm stating anything new here, but I found a new way to remove stubborn brake caliper pistons. Screw a grease fitting into the brake line thread, and pump that thing up using your hand grease gun. The advantage over air is the pistons don't come flying out. Just a nice, smooth extraction.
The downside is you need to run it through a solvent tank, as it will of course, be filled with grease.
I hope this helps someone!
all cars sold.
Old 05-13-2004, 05:49 PM
Thanks Jay. Your tip may come in handy. I'm doing all 4 corners next week- calipers, hoses, bearings,etc.. Ray
Ray
'88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia
Old 05-13-2004, 05:52 PM
fancytown
Good luck Ray! You're saving yourself a bundle. If you do use air DO NOT get your hand in the way of the piston. It will crush your fingers. On my '72, the brake line thread was an M10 x 1.0mm pitch (this is a fine thread). Might make the fitting search a little easier
all cars sold.
Old 05-13-2004, 05:56 PM
Jay,
Get the engine installed and running. Stop worrying about silly things like brakes.
-Bernie
fancytown
HAH--I was about to "schedule" the install...I bled the brakes, and the rears were completely locked up after pumping the pedal for the final "test". These things were really rough, I'm glad I did it.
all cars sold.
Old 05-13-2004, 05:59 PM
Nice Idea!
I used a 12volt air compressor plugged into the cig lighter for all of mine.
'70 911T Signal Orange
Old 05-13-2004, 06:49 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
I used air. First piston, I didn't remove fingers and piston almost did. Darn , that smarts! Getting the rubber piston boot with metal band on is a true bear and can result in rubber tears. I made a tool out of 1.5 in PVC pipe on which I thinned the wall.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 05-13-2004, 08:31 PM
Zeke's Avatar
When using air, I put a block of wood in between and then a towel over so the residule fluid dosen't go all over. That happened once before I learned.
Old 05-13-2004, 09:22 PM
notmytarga's Avatar
I had similar control with a bicycle pump - and no grease. The brake fluid wreaked the plastic valve clamp head - but it worked better using the hose directly to the hard brake line.
A new grease gun without grease would be a nice controlled pump.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 05-13-2004, 10:52 PM
IROC's Avatar
To expand on this good suggestion, I use a block of wood and C-clamp it to the piston I don't want to remove (so that it can't move) and blast the other one out with air pressure.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-14-2004, 05:00 AM
