-   -   My First Major Project (http://forums.pelicanparts.com/porsche-911-technical-forum/162923-my-first-major-project.html)
OZCarrera3 05-13-2004 06:14 PM
Hi all,
Well, will be starting my first major project on the car tomorrow with much appreciated assistance a fellow Pelicanite and PCQ member Steve Foss (SteveF_911 ).
I'm pretty excited as we'll be dropping the engine to investigate some of my car's numerous oil leaks and undertake a few upgrades. Of most concern to me is the oil leak from the rear (pulley end) of the motor, which we're hoping will be the main seal, but maybe the No. 8 bearing 'o' ring. Whilst the engine is out will also be doing the following:
clean engine
check condition of clutch & pressure plate
powder coat fan and tin ware
clean and tidy up engine bay
install new engine sound pad
install 28 bar oil cooler
polish and fit 8" Fuchs
Should be an interesting process, just hope there aren't too many surprises! Will be taking photos along the way and will post any items of interest.
raceman 05-14-2004 06:50 AM
watch the powdercoating.you may want to take a bit off the tips of the blades,when l did mine it rubbed on the housing due to the buildup.Have fun amigo
JRISER 05-14-2004 07:37 AM
Cool! I can't wait to see the pictures.http://www.pelicanparts.com/support/...s/boldblue.gif
BTW, I am planning something similar to this at a later date.
Schrup 05-14-2004 07:42 AM
Sheldon, sounds like fun. I hope to drop my motor next winter to clean everthing up myself.
bigrubberjeep 05-14-2004 07:50 AM
Why do you want to put in a sound pad? Do you want to hear your motor less?
Mike Andrew 05-14-2004 09:08 AM
Ditto on the powdercoated tips. I would have them masked. I rubbed mine also - heat = expansion. Add some stretch & you are trying to clean powdercoat off of your fan housing.
(my Saturday project)
Fishcop 05-14-2004 05:29 PM
I'll be eagerly following your exploits... I've got to dress up the engine I'm building.
Watch Fossy doesn't swap your 3.0 for his 2.0...
OZCarrera3 06-10-2004 03:24 AM
Well guys, what did I say in the original post? Something along the lines of "just hope there aren't too many surprises"?
Well, the engine has now been completely dismantled after finding that it was definitely the No.8 bearing housing that was leaking. Earlier this week I submitted the crank, rods, pistons, barrels and heads to my local P-car expert for measurement and a general cleanup. Here are his findings...
Crank - A1
Rods - A1
Pistons - toast, skirts and ring gaps worn significantly
Barrels - toast, no longer round
Heads - all 6 exhaust valves and 12 valve guides toast!
:eek:
Well, now in the process of ordering all of the above items, along with the other bits and pieces already identified as needing replacement.
This is going to rather bruise the bank balance (about $AUD5,000 in parts so far), but when it's all paid for and done, I'll have a new motor! And also been told that the the late SC (81-83 204 hp model) high compression pistons will fit without any modifications, thus giving me a significant hp increase (around 20hp to 220hp I believe) - sweet!! :)
Will post some pics in the coming weeks.
