Help finding old Thread on seat top Swap
A while back I saw a thread on how to reverse the top portion of the front seats [the seat backs], but can't find it now. I want to pull the seats this weekend for other maintenance and thought I'd reverse the tops portions to even out the wear. Can't seem to find it. Don't want to just start yanking . . .
anyone recall that and can provide link? thanks, todd 86 coupe |
Warren & Ron, may you rest in Peace. |
You do not have permissi
After buying some cheap used high-backs from a middle year car, I switched the whole things because the original OEMs were pretty sagging on the back.
The controls are on opposite sides but the base/bracket mounts are the same. Made a big difference in comfort. The sheepskin covers helped make them pimpalicious as well as soft, warm, and a little more firmness. Even if yours are powered, they may be able to be swapped out whole. Not sure how they come apart. |
Thanks guys. I found the post and it says it is easy [a few bolts and a few hooks for the latches]. On mine the backs both have two latches and it does appear they are identical.
todd 86 coupe |
