amersbell's Avatar
Question Odometer Broke
Do I just need to get a new speedometer if my odometer stopped working on my 81 SC 3.0? Maybe 120 mph instead of 85 mph?
Chris Bell
Confused owner with more 911 questions than answers......and no one to ask in West Texas.
1971 Targa, 1981 911 SC Targa, 1995 993 Coupe
2008 Cayman
Old 05-15-2004, 12:21 PM
scottb's Avatar
Don't tell me, lemme guess -- you hit the trip reset button while the car was moving (even a little). If you did, then it's likely the little gear inside the speedo is toast. Common problem.
Go to www.odometergears.com and you'll find the part to fix it. I think there's a Pelican tech article on how to do the repair. Or, send the entire unit to North Hollywood Speedometer and they'll be able to fix you right up!
Don't worry...this is likely not a big deal.
1984 Targa
Old 05-15-2004, 01:47 PM
amersbell's Avatar
Bought it that way, two weeks ago.
Chris Bell
2008 Cayman
Old 05-15-2004, 01:51 PM
scottb's Avatar
Then the PO did the deed. It's a common mistake...and a relatively easy fix.
1984 Targa
Old 05-15-2004, 01:58 PM
What freekin Oil Leak?
TurboBert's Avatar
At the risk of being branded a herectic, I think "hitting the trip reset button while moving will break the odometer" is really a myth. From my limited experience, the usual cause is that the plastic gears get soft with age and just start to crumble.
'79 930 US
Old 05-15-2004, 01:59 PM
greglepore's Avatar
I often has nothing to do with the reset - mine had a gear that was completely brittle with age-apparently they're lubed and the lube breaks the plastic down. The website posted is a great resource.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
amersbell's Avatar
Thanks Scott.
By the way I've got a friend tat just bought the NOTAR Helicopter. Really nice.
Chris Bell
2008 Cayman
Old 05-15-2004, 02:00 PM
From the www.odometergears.com site:
"Another myth is your gear breaks when you hit the reset while moving. Your gear broke because VDO put oil on the rubber gear. The heat from the sun, over time, disolved your gear."
But a great site to have access to all the same, thanks for the link.
'80 SC
Old 05-15-2004, 06:56 PM
Todd Simpson's Avatar
My gear didn't break, it simply spun on the shaft. A little crazy glue got it all working again, and still holding after 5 years.
Old 05-15-2004, 08:53 PM
Not sure it thats a total myth. My odo stopped working the instant I reset the trip button while rolling.
Old 05-15-2004, 09:39 PM
Binge User
Schrup's Avatar
I accidently hit the reset button while moving once & thought I had dodged a bullet. I would be nice to know for sure.
Paul
Old 05-15-2004, 10:49 PM
TurboBert's Avatar
Consider someone who breaks through a rotted floor by walking on it. You could say the walker broke it but the better answer is that the floor had rotted.
'79 930 US
Old 05-16-2004, 12:40 AM
On a great circle route
xlr8's Avatar
Check out this Pelican Technical Article .
I would personally prefer one of the later 160 MPH guages, a speedo shop might be able to rebuild it as such?
NOTARs are cool!
Russ
Old 05-16-2004, 09:50 AM
19 years and 17k posts...
azasadny's Avatar
I sent my dead speedometer/odometer to North Hollywood Speedometer this spring and they sent me my rebuilt uint two weeks and $150 later (included shipping). The rebuilt unit works great!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 05-16-2004, 06:58 PM
