jwmc1's Avatar
Carerra 3.0 Engine
I have a 1980 SC Euro, but for some reason it has the 930/02 engine in it. I don't know why, but the car runs well and the deal was such that I didn't care. My questions is this, do I have a better engine (provided the engine is in good shape of course) with the Carerra 3.0 or is the SC engine better? Which would any of you rather have?
John
Old 05-17-2004, 03:49 AM
IROC's Avatar
Its arguable which engine is "better", but I think it is cool having the 3.0 liter Carrera engine. I'd wager the 3.0 liter Carrera engine is more valuable...
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-17-2004, 04:42 AM
jwmc1's Avatar
Thanks., that is my original thought as well
John
Old 05-17-2004, 04:10 PM
Bill Verburg's Avatar
The C3 was a great engine for it's time, but so are some of the later SCs. Main fault of a C3 is the higher maintainance point type ignition.
Bill Verburg
Old 05-17-2004, 04:12 PM
vash's Avatar
nice car, you should lower it a bit.
poof! gone
Old 05-17-2004, 04:13 PM
jwmc1's Avatar
this may sound lame, but how do you lower it?
John
Old 05-17-2004, 04:18 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Depends on how you look at it. The C3 had a different case than the SC. It won't take a 74.4mm crank like an SC will but it does take a 2.0-2.7 crank. Which means you can make a rock solid 2.8L motor(a 66x95mm motor is pretty rare). On the other an SC motor can be built up to 3.5L or larger. If the motor runs well this probably doesn't mean much to you. I do belive the C3 had a little more HP than the early SC's as well. Talk to Noah P. He knows all the ins and outs of a SC vs. a C3.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-17-2004, 04:26 PM
jwmc1's Avatar
I have spoken to him, you are correct...the SC had 180 BHP and the C3 has 200 BHP....
John
Old 05-17-2004, 04:29 PM
jwmc1's Avatar
That doesn't excite me too much...I guess I should enjoy while I can!
John
Old 05-17-2004, 05:59 PM
