robhamster's Avatar
lopsided front end
My '84 Cab 911 has a front end that is lopsided. the driver side is about 1.5" lower than the passenger side at the wheels. It has been like this for about a year and I do not see any bad wear on the front tires. Is this due to a bad shock insert?
1984 3.2 Cab (now toy)
1975 911S (old toy)
Mercedes E350 W4 (snow car)
2007 911 Turbo (water and air pumper)
2012 Panamera 4S (for the wife, I swear)
Old 05-16-2004, 07:20 PM
kqw kqw is offline
Height adjustment maybe?????
How does it handle as this may be an indication of the problem.
The Fox
Carrera
Old 05-16-2004, 08:12 PM
There could be several reasons for this situation:
1) LF/RF height adjustment is not the same
2) LR or RR height adjustment is affecting the front
3) Chassis is twisted due to collision damage
4) LF or RF torsion bar is broken/distorted
Do you hear any noise from the front end?
Bad/worn strut does not support the vehicle.
Sherwood
Old 05-16-2004, 08:24 PM
Maybe Nutri Slim?
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 05-16-2004, 09:33 PM
robhamster's Avatar
Ouch, Nutri Slim!
Thanks, I will look at the height adjustment. Before I dig into Bentley's too far, is this something I can do? There is no noise and the car handles just fine.
1975 911S (old toy)
Old 05-17-2004, 04:22 AM
I've adjusted the front end. It's easy. Just one screw on each side. Wayne's book covers it well. Or, look up height adjustment or ride height on the site. PS, If you make a big adjustment I would have the front end re-aligned when you're finished.
Old 05-17-2004, 04:43 AM
It may or may not be as easy as just rotating one or both front end height adjusters. As I mentioned previously, there could be some weight jacking from the rear end height adjustments. Here's what I suggest (or your repair shop look into):
To eliminate the rear end as a factor, raise and support the rear end from a single point in the back (under the transaxle mount). This transforms the car from 4 support points into a 3-point support - a tripod. In this configuration, any difference in LF vs RF ride height is solely attributed to the front, then use one or both adjusters to get the ride height to within desired specs. If the side-to-side front end height changes when the car sits on all 4 wheels, then you must look elsewhere for the imbalance (e.g. repeat the procedure for the rear end).
Ideally, the front sway bar should be disconnected for precise front end adjustments, but you'll be close enough using the above procedure.
Sherwood
Old 05-17-2004, 08:08 AM
