Bill Verburg's Avatar
Any body ever seen one of these?
Bill Verburg
Old 05-16-2004, 01:25 PM
ZAMIRZ's Avatar
C4 lightweight, oh my gawwwd, this car makes me weak on the knees. This is my favorite feature:
Fully tunable front, rear and center diff so you can dial in oversteer/understeer on the fly at the turn of a knob!!!
There was one for sale in the UK for about 140,000 pounds a while back, had like 9 miles on the odo if I remember correctly.
Amir
'83 911SC
Old 05-16-2004, 01:32 PM
That thing was so packed w/ gee whiz items..
here's another
Bill Verburg
Old 05-16-2004, 01:35 PM
That's interesting, I thought those were brake proportioning controls. The ability to control the AWD system is way cool. There's an aftermarket module similar to that for the Haldex controlled Audis and VWs. I have heard that it's alot of fun.
Old 05-16-2004, 01:45 PM
Yeah, I saw that yesterday too. Very trick car, you walk by and see another plain Jane 964, at first, then all the little things start popping out at you.
Old 05-17-2004, 04:00 AM
Porsche's Avatar
Erwin
'97 Boxster (sold), '67 911S (sold), '77 911 (sold)
Definitive Australian/ New Zealand Porsche Resources
Old 05-17-2004, 04:35 AM
Metal Guru
911nut's Avatar
911 and Porsche World did a feature on an identical car last year. According to the article those are very rare, built for a racing series that never got off the ground. I think only 18-19 were built.
The engine isn't especially trick (balanced and blueprinted by the factory) but the car is gutted, no body schultz, all the seams welded solid, ect.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 05-17-2004, 05:37 AM
Where was that gathering of porsches? Is Loudonville far from the city?
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 05-17-2004, 07:40 AM
bigrubberjeep's Avatar
Beautiful!
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 05-17-2004, 09:13 AM
Zeke's Avatar
It has a left/right arrow and and fore/aft arrow for the other knob. How does it work?
Old 05-17-2004, 09:32 AM
I thought those knobs were plow controls at first. I thought it was a joke or something...............
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 05-17-2004, 09:45 AM
Glasgow 911SC's Avatar
Carrera 4 RS Lightweight
Facts & figures
1990 Carrera 4 RS Lightweight
ENGINE
Rear-mounted, air-cooled, all-aluminium flat-six with two valves per cylinder operated by single chain-driven overhead camshaft per cylinder bank. Bosch Motronic M2.1 electronic fuel-injection and management system; twin spark plugs
Capacity: 3600cc
Bore & stroke: 100.00mm x 76.4mm
Compression ratio: 11.3:1
Maximum power: 260bhp at 6100rpm
Maximum torque: 2401b/ft at 4800rpm
TRANSMISSION
Type 953 five-speed, close-ratio manual
gearbox; four-wheel drive with adjustable
and electronically controlled centre
differential; limited-slip differentials
front and rear
Ratios: 3.50:1 (1st)
2.06:1 (2nd)
1.41:1 (3rd)
1.07:1 (4th)
0.86:1 (5th)
Final drive: 4.625:1
SUSPENSION
Front: MacPherson struts with aluminium
'A'-arms and adjustable anti-roll bar
Rear: Semi-trailing arms with coil-over
dampers and adjustable anti-roll bar
BRAKES
Front: 320mm cross-drilled and vented
discs; four-piston calipers; Pagid pads
Rear: 300mm cross-drilled and vented discs;
WHEELS & TYRES
Front: 7.0J x 16-inch magnesium Design 90
rims (see text) with 205/50ZR16 Yokohama A-
008P tyres
Rear: 9.0J x 16-inch magnesium Design 90
rims with 225/50ZR16 Yokohama A-008P tyres
DIMENSIONS
Weight: 1100kg (24251b)
Wheelbase: 2271mm
Length: 4250mm
Width: 1651mm
Height: 1321mm
PERFORMANCE
0—62mph: under 4.0 seconds (estimated)
Maximum speed: 120mph (6500rpm in fifth)
Price new (in 1990): Dm285,000
(approximately £100,000)
I could have a go at scanning the full article from 911 & P World but getting good resolution under 100k is pretty tough.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 05-17-2004, 10:07 AM
