Irrationally exuberant
ChrisBennet's Avatar
Oil test
I came across this today and thought is was interesting. It's an Amsoil ad but it has the ASTM motor oil tests results for several brands.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-20-2004, 09:18 AM
Chris:
It is indeed interesting reading. Some thoughts do come to mind, however.
--- notice that 10w-30 was the common theme. How do the other weights compare ( 20W-50)? Where is Shell's Rotella-T, or Mobil Devlac 1300?...industrial-strength mineral oils not often seen at Wally-Mart, but ARE available?
--- some graphs don't start at "0"..and give a false bar-graph impression of degree-of-difference.
--- unless we have some base-line data on what the "poorer" performance numbers mean ( in real life), the "extra-goodness" of the superior numbers are just "better"....but how much more-so?
Sorry...just being the analytical , doubtfull engineer crumudgeon ( by training, it seems!) ...
--Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-20-2004, 09:41 AM
IROC's Avatar
Originally posted by Wil Ferch
--- unless we have some base-line data on what the "poorer" performance numbers mean ( in real life), the "extra-goodness" of the superior numbers are just "better"....but how much more-so?--Wil
I think this is what it all boils down to. Sure, there are oils out there that are "better" than other oils. What does that translate to in real-world performance, wear and longevity in your engine?
That's the part, to me, that has never been quantified to my satisfaction.
We had a lubrication expert (this guy had essentially dedicated his life to lubricants - it was scary) give a talk at the local PCA region tech session and his response to the age-old question of "which oil is the best" was simply, "Buy a good, name brand oil". That's it. He even said that synthetics offer no benefits unless you live in an extreme environment (such as Alaska where lower pumping points are important).
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-20-2004, 09:59 AM
