echrisconnor's Avatar
Show me your SSI Oil Plumbing
I'm looking for a shot of how the oil lines route when you do an SSI conversion, or have the back dated oil lines and a front cooler. Specifically, I need a shot inside the right rear weelwell of how the lines stack and are arranged.
Thanks all!
'76 911 Carrera 3.0
Old 05-18-2004, 02:28 PM
Bill Verburg's Avatar
Well since you have a '76 C3, here's some shots of my '76 C3
Ignore that heat part, the 3 L doesn't use that set up.
Bill Verburg
Old 05-18-2004, 02:55 PM
Bill,
What oil lines are those that you're using? They don't look like the setup I've seen in parts diagrams:
'76 911 Carrera 3.0
Old 05-18-2004, 03:49 PM
Or maybe they are... Is the union from the line which bumps under the transmission obscured by line "B"?
'76 911 Carrera 3.0
Old 05-18-2004, 03:50 PM
The lines are from a 74 Carrera I believe. That was done a looong time ago. They were also relocated to fit into the crease in the fender well better. The A line(16 in the parts diagram) goes to the union(on 15 in the parts diagram).
Bill Verburg
Old 05-18-2004, 03:59 PM
chrisp's Avatar
my lines are oriented exactly like the parts diagram illustration. The new line going to the backdated hard line is closest to the tire. I was originalyl worried about clearance but with my 255 tires on 9" rim I have about 1.5" of clearance.
'83 SC
Old 05-18-2004, 05:47 PM
