Noel's Avatar
Anyone backdated heat and kept A/C?
I've seen in past posts that it seems like it can be done, but no one has spoken up to say, I have done it and it works. Anyone???
I wanted to check before I spend the $$$ on the right side diverters only to find that they will not fit under the A/C compressor bracket.
Thanks.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 05-19-2004, 07:10 AM
jdowty3's Avatar
Back dating the heat system doesn't affect any part of the AC system. The SC heat system works off the rear blower and heat exchangers. The AC system uses the evaporator fan in the smugglers compartment. I upgraded my AC system last year and plan to back date the heat when I can get the required parts at a good price.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 05-19-2004, 07:45 AM
Noel's Avatar
Jim that is true, however, my real question is can the A/C compressor still be in place with back dated heat, due to the location of the blockoff plate the hose.
Old 05-19-2004, 08:44 AM
Hilbilly Deluxe
emcon5's Avatar
Yes.
It isn't much fun to get the hose on if the compressor is in place, but it fits.
Tom
82 911SC Coupe
GTI Cup #43
Old 05-19-2004, 09:21 AM
