Angry idle adjustment on my zenith
hello,
I have a 911T from 1970 with zenith carbs. But if it runs idle , it runs uneven and i think on 4 or 5 cylinders. With higher rpm's it runs perfectly!
I have adjusted the valves propely, new spark plugs , good marelli and timing is set. I have set the mixture screws on 2 1/2 out as in the hand book.
Can anyone give some information how to adjust my carbs on idle because i think I am forgetting something??
Old 05-19-2004, 04:53 AM
Home of the Whopper
2 1/2 turns is just an initial set up. You have to measure the airflow into each cylinder and adjust the mixture screws to even out the flow.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-19-2004, 09:46 AM
911ctS's Avatar
Send a message via Yahoo to 911ctS
Like what BK said... you will need a uni-syn or syncrometer to measure airflow at each stack while at idle and adj. air bypass screws. Then do idle mixtures. Also make sure you hand throttle is all the way down while adj. the carbs.
_____________________________
Clint Smith
www.RebelRacingProducts.com
1970 911T ----> RGruppe RS/R (mexico blue)
1995 993 becoming an RS (gran prix white)
Old 05-19-2004, 09:55 AM
These carbs are usually worn and getting the adjustment right is virtually impossible.
Good idea - set it right at idle and then idle around the bends all day.
I say, stuff the idle and set it for best mid range - top end.
Steve in South Africa
If it isn't sideways, it isn't fun
Old 05-19-2004, 11:24 AM
