falcon's Avatar
Grinding noise when turning steering wheel
Backed her out today and noticed a grinding sound as I turned the steering wheel. Made some turns and the same grinding (noise much like bearings with no lube) sound in both directions coming from the steering column.
Any ideas on what this can be appreciated.
Randall
1988 911 Cabriolet (SW Chip)
2000 Honda Civic (4dr wifey mobile)
2001 Honda S2000 (daily driver)
2003 Honda Odyssey (family truckster)
1978 911 SC coupe (Sold)
My 911 Cab Pics
Old 05-22-2004, 09:00 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest grinding noise
Probably, the slipring / wiper contact.
Old 05-22-2004, 09:14 AM
Chuck Moreland's Avatar
Re: grinding noise
Could be the wiper if it is a scraping sound and the wheel turns smoothly.
If it is crunching sound it is likely the "U" joints in the shaft. There are two and they should be lubed every 50k miles or so. If it is the "U" joints you will likely feel it in the wheel, a jerky action.
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-22-2004, 09:58 AM
GrindingGears's Avatar
Do a search on this question. There was a longer thread recently that had some solutions to this issue. Try searching, "steering wheel noise" or something to that effect. Good luck...
I had this problem a few months ago, ignored it and it went away.
83 SC (gone) // 72 T (gone)
Old 05-22-2004, 10:01 AM
