Installing New Carpet
I have a couple of questions for installing my new carpet:
What's the best process in removing the old adhesive from the sheet metal and sound deadening material.? How do you attach the front left and right carpet pieces? ie do I need to pull out the weather stripping (near the door hinge)? Pulling the old carpet out of these seams was difficult and I don't know how I will put the new carpet in at the weather stripping. What's the best adhesive to use when I put the new carpet in? Thanks for all your help. Zac |
You can use the 3M adhesive remover or diluted paint thinner (which is basically what the 3M stuff is) and a scotch bright sponge. I also found a plastic spackle knife to be useful.
Thanks, I''ll try that. And for the new carpet how is the 3M adhesive?
| All times are GMT -8. The time now is 12:00 AM. |
