aj88cab's Avatar
Help! Power Bleeder Blowout - what happened!
I was using my new power bleeder for the first time. I had rebuilt the calipers and was going to flush and bleed the system with new Blue stuff. Followed all the instructions. Hooked it up, pumped it up to about 12psi. Start to walk to the right rear tire to start the bleeding process. I hear liquid. I look under the car and see a large puddle and its getting larger. I released the pressure on the power bleeder but not before 2/3 of the quart dumps on the carport. There is a small pool of fluid under the brake power booster, and a little under the battery. Most of the stuff on the ground came out of a plugged hole in the frame. See picture. Doesn't look like there is anything inside the car.
This is not the kind of stuff that is supposed to happen 3 weeks before my first DE.
Any ideas on what happened? What broke? What needs to be fixed!
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 05-25-2004, 03:20 AM
i guess you forgot to block off the overrun hose
btw clean up very good with water !! this stuff eats paint.
87 Carrera Backdate
Old 05-25-2004, 03:24 AM
Licensed User
Shuie's Avatar
Same thing happened to me last night. I have yet to do anything right on this car the first time Ive tried.
There is a overrun hose that goes from the top of the master cylinder reservoir to a small tank right above that in the front pan. By the time I had the rear passenger side caliper done I had pumped at least a liter of brake fluid through that hose and into the front pan of my car. I was so pissed I wiped it up an quit for the night. I'll try again today.
Old 05-25-2004, 04:01 AM
Andrew, what kind of brake pads are you going to run at the DE?
Ray
'88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia
Old 05-25-2004, 04:38 AM
If all else fails read AND FOLLOW the instructions on the power bleeder. On the system with the vacuum booster there is a chance one of the hoses/gromments between the reservoir and the MC is leaking due to a combination of age and excessive bleeding pressure. There is really no reason to exceed 10 to 15 psi. Jim
Old 05-25-2004, 06:46 AM
You may also want to put a hose clamp on the overflo tube, I found that when I clamped it off I had leakage at the connection of the hose to the fluid reservoir, a 30 cent clamp took care of the issue.
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 05-25-2004, 06:59 AM
Super Moderator
cstreit's Avatar
It was the overflow tube. That's where it vents to.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-25-2004, 07:44 AM
aj88cab's Avatar
Yep, there it is, the over flow hose, still dripping the last few drops of ol' Blue.
I feel better....I guess
Thank guys.
Old 05-25-2004, 08:06 AM
Overfow tube. Again. I guess everyone has to go through it once to figure it out. Damn those instruction.
Caliber
1987 911 Cabriolet
Old 05-25-2004, 10:49 AM
Brake fluid makes a mightly fine paint remover. I hope you rinsed it off.
Sherwood
Old 05-25-2004, 11:17 AM
Automotive Monomaniac
Emission's Avatar
I did the same thing - you are not alone.
P.S. - I just got some new PBR "Ultimate" brake pads for DE use. We'll see how they do.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 05-25-2004, 12:11 PM
joecrum's Avatar
I'm doing mine on Thursday! ...glad I read this!!!
joe
>82 3.0 SC
>01 Audi S4 Avant
Old 05-25-2004, 01:02 PM
buttjoint's Avatar
I screwed the bleeder cap to the resevior too tight and the same thing happens. Fluid runs out on the floor. Makes a nice mess
Old 05-25-2004, 02:35 PM
aj88cab's Avatar
I don't know yet. I put in OEM pads for the street. I will change pads for the DE. I am open to any suggestions from folks out there on what they use for the track. Otherwise, I'll take what the good folks at Performance Imports suggest when I have them do my tech inspection.
Andrew
Old 05-26-2004, 02:14 AM
amk amk is offline
amk's Avatar
Andrew,
I've read recommendations not to exceed 10psi (particularly on older cars) because the rubber hoses from this side of the master cylinder are not designed to be pressurized. I typically do mine at about 7-8 psi.
By the way, the underside of your car looks very clean, nice.
Regards,
Andrew.
1976 911 Carrera 3
Old 05-26-2004, 03:16 AM
