Clutch spring
On an '88 911 is there a way to lessen the tension on the clutch pedal, my wife finds it laboring to use the car in traffic situations
thanks for the help
Old 05-25-2004, 09:20 AM
Friend of Warren
Have you checked to see if the "horseshoe" helper spring down by the tranny is broken?
Kurt V
Old 05-25-2004, 09:25 AM
The 88 is hydraulic. Is she still ... not ok with that? There is no way out I am afraid.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-25-2004, 09:50 AM
There was just a blurb about it in Excellence. The needle bearings on the clutch release fork on the 87-89 G50 trans cars. Apparently these needles get gummed up over time and get sticky.
Somehwere, I suspect here at Pelican, there are better aftermarket parts to replace this bearing assembly. Of course this will require and R&R of the motor (~$250 here in CA).
Good luck.
Nick
'85 Carrera
Old 05-25-2004, 09:57 AM
Friend of Warren
My bad. Of course there is no horseshoe spring.
Kurt V
Old 05-25-2004, 09:58 AM
