Voltage Regulator Replacement
It appears like my voltage regulator is going. The AC fan speeds up and the seat belt light is cycling on and going off. How big a deal is it to replace it my self?
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
It's a breeze. Removing the alternator is the hardest part. The diode board is easy to replace too, at least on a Paris Rhone.
Seat belt light?
78SC coupe, Silver Metallic |
See here:
http://www.pelicanparts.com/techarticles/911_volt_reg_replace/911_volt_reg_replace.htm ---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Seat belt light?
The brushes on your regulator are probably worn down so replacing your regulator/ brush assembly will likely cure the voltage surging as it did when I replaced mine recently.
Cheers, Joe 86 3.2 |
