Voltage Regulator Replacement
It appears like my voltage regulator is going. The AC fan speeds up and the seat belt light is cycling on and going off. How big a deal is it to replace it my self?
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 05-28-2004, 07:30 AM
oneblueyedog's Avatar
It's a breeze. Removing the alternator is the hardest part. The diode board is easy to replace too, at least on a Paris Rhone.
Seat belt light?
78SC coupe, Silver Metallic
Old 05-28-2004, 07:40 AM
See here:
http://www.pelicanparts.com/techarticles/911_volt_reg_replace/911_volt_reg_replace.htm
---Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-28-2004, 07:42 AM
Where can you buy those?
Old 05-28-2004, 07:48 AM
Seat belt light?
Old 05-28-2004, 08:00 AM
Seat belt light?
I think the voltage spike into the module makes it think the car was just started.
Old 05-28-2004, 09:08 AM
The brushes on your regulator are probably worn down so replacing your regulator/ brush assembly will likely cure the voltage surging as it did when I replaced mine recently.
Cheers,
Joe
86 3.2
Old 05-28-2004, 09:12 AM
