993 exhaust on 3.2?
l`ve heard the 993 exhaust can be fit on the 964 engine with minor mods...what are the challanges of fitting to the 3.2? l`m pretty happy with my GHL until l go turbo but l`ve always wondered about this possibility,anyone care to point out the folly of such a match?
my life begins at 150MPH |
yes it can be done, you just have to change the flanges on one of the exchangers, I have a jig for it if you need it, Kevin
I think this has been asked before but I couldn't find it. Could 964 H/E be used on an SC or Carrera to give the same (but cheaper) effect as SSI's? You would have a 2 in 2 out system this way, wouldn't you?
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
so it CAN be done? Sweet,l wish l knew that before l bought the GHL set up.l`ve heard the 993 system gives great power plus it sounds fantastic,but will all that plumbing fit okay aft of the 3.2 also ? and then there`s the heat that needs to be fitted..can anyone post pics ?Those stock 993 headers might work perfect for my twin turbo conversion using Mitsu 13b turbos..
Check out
http://members.rennlist.com/tholyoak/993_flange_flip.htm for pics/info on how I used Kevin's jig to rotate the flanges on the right side exchanger Fitting to a 3.2 should be the same. Todd
1989 911 Targa |
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
the 964 just is way to much work to get them to work, Kevin
