convertible top help needed
1992 C2 cab top doesn't latch. I have checked both latch motors and they run fine.Micro switchs at windshield check out ok. The top goes up and down fine and the micros on the transmission for up and down both stop the top so they must be ok. I need to know if anyone knows how to check the control unit out and/or does anyone have any other ideas as to what I might look for that I might be missing.
Thanks,Earl |
The PO of my Carrera had shelled out about $3000.00 due to a malfunctioning top. A 92 would be similar to mine. Tread lightly, heard those aluminum rails can bend easily. I’ve actually have read that some people convert to a manual top once they’ve took on this monster!
1994 968 "Totaled during practice for GBRS / PCA 2009 Race season" 1989 944 Track car replacement. Complete with 968 running gear. 1988 911 Carrera "Friday / Weekend Driver" 1988 944 Daily Driver now. 1973 911S "In storage" |
If either locking motor is out of sync or damaged (brass gear), the motors won't
run when the micro switches close (top reaches windshield). Each motor has a micro switch which is used to determine its position. If the controller senses the wrong positions, neither motor will run. Also, the controller is the next most problematic cab top system element.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Glad mine is a manual.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
How does the @#! cab power roof work?
check this thread out. use the search function and cab tops. hope this helps
1985 911 Carerra Cab 3.6l 1998 Dodge Ram 2004 Toyota Tundra Quad Cab |
