-   -   Socket-size for SC rear axle stub nut (http://forums.pelicanparts.com/porsche-911-technical-forum/165440-socket-size-sc-rear-axle-stub-nut.html)
Gunter 05-30-2004 11:27 AM
The nut on the rear axle is M20 thread. What is the socket size? Also, some SC's have a much longer cover for the rear torsion bar. Why are there short and long ones? What is the difference? The Bentley, pages 420.... show a much longer cap than I have. Mistery. Thanks anyone? SmileWavy
no substitute 05-30-2004 03:04 PM
30mm if you mean the "Ihadtostandonthebreakerbarextensiontobreakitloose " nut. I used a Lisle GM socket. Don't know the other, but this'll bump it.
ga_mueller 05-30-2004 05:27 PM
Have fun with the nut. Twisted off my 1/2" with 9 foot extension like cheese. The Harbor Freight 3/4" drive ($20) did the trick, it was amazing how easy it came off.
Gunter 06-01-2004 05:37 AM
Thanks, no substitute. Ga_Mueller: Is the socket size 30 mm the same on a Carrera? Or did you use standard?
ga_mueller 06-01-2004 09:16 AM
Gunter
The socket size on my Carrera is 32mm. A no-name 3/4" drive socket with a 4" extension worked fine. And a 9ft steel pipe....
George
