"Cheap is expensive"
Wondering alignment, something I didn't know
I had my alignment done a couple weeks ago but needed to address the front camber by modifying the top strut plate. I tracked my car the following week before getting the front camber modified and then re checked and tweaked. I still have the stock bushings both front and back and know the alignment will wonder driving the car hard. Guess what? Even before the camber was tweaked it was obvious from the before alignment and when the car was setup now that the alignment had changed some. So I guess the old rubber bushings are shot and don't have any memory left. I didn't think the alignment would change if your not driving the car or is there something else wrong? Has anyone else seen this happen? Anyhow even though my car is mainly street I will probably go with the Elephant Racing bushings when I make the change. I think new rubber should bring the alignment back when not driving the car but in due time the alignment won't hold which is expensive and a PIMA.
Thanks,
Brent
Old 06-01-2004, 09:14 AM
Make sure you're checking the before and after situation with the same amount of gas or other load in the car....
---Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-01-2004, 09:25 AM
driver
porcupine911's Avatar
i wonder when this wandering problem will be solved.
- chris
Street: 1971 911E, 2007 GTI 2.0T, 2012 Cayenne Turbo, 2019 GTI TCR, 2022 Boxster 25 years
Circuit: 2020 Cayman GT4
Old 06-01-2004, 09:40 AM
